Tutorial - Integrate Rhino/Grasshopper
Estimated time: 45 minutes
Difficulty level: Intermediate
  • Not a reader? feel free to follow this tutorial as a video
    Introduction
    Welcome to this tutorial on integrating Grasshopper with VIKTOR! In this tutorial, you will learn how to create a VIKTOR web app with a Grasshopper model running behind it by the following steps:
    1. Setup integration with Grasshopper
    2. Build the VIKTOR app
    3. Use your own Grasshopper model
    By the end of this tutorial, you will have created a simple VIKTOR application that creates a geometry and data view of a simple box, see the image below:
    So, let's get started and learn how to create a VIKTOR app based on a Grasshopper model!
    Pre-requisites and downloads
    Prerequisites
    • You have installed VIKTOR on your computer
    • You have some experience with reading Python code
    • You have some experience with Rhino/Grasshopper
    Required Downloads
    SDK version
    This code requires support for the GrasshopperAnalysis, which is available since SDK v14.8.0. Make sure use this SDK version or higher in your requirements.txt file.
    Explanation of setup
    Before diving into the steps, let's explain how the integration will work. See the following diagram:
    The following will happen:
    1. The user fills in input parameters in the VIKTOR UI
    2. In VIKTOR app.py these input parameters will be sent together with a Grasshopper script (sample_box_grasshopper.gh) to the worker.
    3. The Grasshopper worker will run Rhino/Grasshopper (on your local machine), based on the Grasshopper script (sample_box_grasshopper.gh) and the input parameters.
    4. The Grasshopper model generates output data, which is sent back by the worker.
    5. In VIKTOR app.py, the output data is converted into a 3dm geometry file, which will be visualized in the VIKTOR UI.
    Now let's setup everything to get this running! We will go through the diagram from right to left.
    Rhino 8 - plug-ins & .NET
    In order to install some older plug-ins, you may have had to set your .NET such that it is running in .NET Framework. If you did, please change it back to the default setting (.NET Core) for the integration to work using the SetDotNetRuntime in the Rhino command line.
    A worker (integration) is a program that connects a VIKTOR app with third-party software to execute tasks and send back results. In this case, the worker will start Rhino/Grasshopper with the input data and send the resulting output data back. Before we setup the worker, we must first install the Hops plugin for Grasshopper.
    Install Hops plugin
    Hops is a plugin for Grasshopper, which will be used to make it possible to call the Grasshopper script externally, using a local Rhino Compute server. Follow these steps to install Hops:
    1. Install Hops via the Package Manager in Rhino (type PackageManager on the Rhino command line and search for "Hops")
    1. Make sure Rhino Compute will be launched at start up. In Grasshopper, go to File -> Preferences and check the following settings:
    We recommend to uncheck Hide Rhino.Compute Console Window, because you can then easily see if Rhino Compute is running and debug when necessary.
    The full documentation of Hops can be found in the Rhino documentation.
    Install Grasshopper worker
    Follow these steps to install the worker:
    A personal worker connects the Grasshopper installation on your own machine, for your own use. Personal workers are installed and managed with VIKTOR Desktop:
    1. Download and install VIKTOR Desktop and log in with your VIKTOR account, if you haven't done so already
    2. In VIKTOR Desktop, click "Add" and select Grasshopper
    3. Configure the worker where needed and start it
    Grasshopper workers that were installed with the previous per-worker installer keep running, but new personal workers can only be added through VIKTOR Desktop.
    localhost port
    By default, the local RhinoCompute server runs on http://localhost:6500/, so this has been preselected in the worker setup. If you have configured RhinoCompute to a different port, please update this accordingly when configuring the worker.
    Once the worker is enabled in VIKTOR Desktop, the app shows whether it is connected. If you installed the worker with the per-worker installer (as used for organization workers), the worker starts up automatically after installation and you will be presented with the worker terminal in which the message: "Successfully connected to the server" is displayed. In the top right corner in your viktor environment you should see a green indicator in your integrations overview, see the figure below.
    Nice work! The integration is ready to use, let's test the VIKTOR app.
    (optional) Check out Grasshopper model
    Before we start building the app, you might be curious to know what kind of Grasshopper model we will be integrating. If you want to check out the Grasshopper model, open the Grasshopper file (sample_box_grasshopper.gh) with the Grasshopper plugin and this should lead to the following view:
    Let's take some time to check out what is happening in the Grasshopper script:
    1. Three Hops input parameters (width, length and height) are defined based on the Get Number component of Hops.
    2. A simple box is created based on the width, length and height, which is subsequently meshed.
    3. The mesh is baked into Rhino using the Context Bake component of Hops.
    If you change the input parameters, you will see that a box is drawn in Rhino. With this setup, we are ready to run this Grasshopper file from a Python script.
    Create an empty app
    Let's create, install and start an empty app. This will be the starting point for the rest of the tutorial. But before we start, make sure to shut down any app that is running (like the demo app) by closing the command-line shell (for example Powershell) or end the process using Ctrl + C.
    1. Open a terminal and run the following command to create the app on the VIKTOR platform and generate the initial code locally:
      viktor-cli create-app "Grasshopper tutorial" --init --app-type editor
    2. Open the newly created folder in your code editor and run viktor-cli clean-start in the terminal to install dependencies and connect the app to the platform.
    INFO    : Connecting to cloud.viktor.ai...
    INFO :
    INFO :
    Re-starting your app
    • You only need to create an app template and install it once for each new app you want to make.
    • The app will update automatically once you start adding code in app.py, as long as you don't close the terminal or your code editor.
    • Did you close your code editor? Use viktor-cli start to start the app again. No need to install, clear, etc.
    Add input fields
    We will add 3 input fields to our app: width, length and height using the NumberField.
    1. Open app.py, import viktor and add the relevant fields to your parametrization. In the end your app.py file should look like this:
    intro = vkt.Text("## Grasshopper app \n This app parametrically generates and visualises a 3D model of a box using a Grasshopper script. \n\n Please fill in the following parameters:")
    # Input fields
    width = vkt.NumberField('Width', default=5)
    length = vkt.NumberField('Length', default=6)
    height = vkt.NumberField('Height', default=7)
    1. Refresh your app in the browser, and you should see the input fields appear.
    Install additional dependencies
    In the next step we will need the rhino3dm package. To be able to use this, we have to add it as dependency in the requirements.txt file so that the contents look like this:
    viktor==14.36.1
    rhino3dm
    If your terminal is still running, close the connection using Ctrl+C.
    Install the rhino3dm dependency:
    viktor-cli install
    And start your app:
    Add the Python code to run Grasshopper
    Now the app code can be extended to integrate the Grasshopper script.
    First, place the sample_box_grasshopper.gh file in the 'my-grasshopper-app' folder.
    Then change the code in app.py to the code below:
    import json
    import rhino3dm
    intro = vkt.Text("## Grasshopper app \n This app parametrically generates and visualizes a 3D model of a box using a Grasshopper script. \n\n Please fill in the following parameters:")
    # Input fields
    @vkt.GeometryView("Geometry", duration_guess=10, x_axis_to_right=True, update_label='Run Grasshopper')
    def run_grasshopper(self, params, **kwargs):
    grasshopper_script_path = Path(__file__).parent / "sample_box_grasshopper.gh"
    script = vkt.File.from_path(grasshopper_script_path)
    input_parameters = dict(params)
    # Run the Grasshopper analysis and obtain the output data
    analysis = vkt.grasshopper.GrasshopperAnalysis(script=script, input_parameters=input_parameters)
    analysis.execute(timeout=30)
    output = analysis.get_output()
    # Convert output data to mesh
    file3dm = rhino3dm.File3dm()
    obj = rhino3dm.CommonObject.Decode(json.loads(output["values"][0]["InnerTree"]['{0}'][0]["data"]))
    file3dm.Objects.Add(obj)
    # Write to geometry_file
    geometry_file = vkt.File()
    file3dm.Write(geometry_file.source, version=7)
    return vkt.GeometryResult(geometry=geometry_file, geometry_type="3dm")
    If you now refresh your app, you should see the following:
    Now press the Run Grasshopper button (be sure that the worker, Rhino and Grasshopper are running). You should see that Rhino Compute is run by the worker which will result in the following:
    Congratulations, you now have made a VIKTOR app with a Grasshopper model running behind it!
    If you would like to integrate your own Grasshopper model in VIKTOR, you can adapt the app you just created. Take the following steps:
    Extend your Grasshopper model
    As explained in this section, some specific things need to be defined in the Grasshopper model to make the integration work.
    1. Connect your specific input parameters by Hops components. In order to update the parameters via Rhino Compute, create Hops Get Components for the parameters you want to update. As you can see highlighted in the image below, the names need to be exactly the same for the integration to work.
    1. Mesh your final geometry. In order for Rhino Compute to successfully export your geometry you need to mesh it because Rhino Compute can only export a mesh. If you don't, your geometry will not appear in the environment.
    2. Add the Context Bake component. The Grasshopper node Context Bake is needed to bake the model.
    Flatten your inputs
    It is recommended to flatten the inputs in your grasshopper script, especially for simpler/smaller scripts. For larger grasshopper scripts, this may still be true, but it may be more efficient to use the Tree structure as input.
    Want to find out more? Check out the thread on the community.
    Adjust the VIKTOR app code
    In the VIKTOR app code adjust the parametrization to match with your required input parameters.
    The rest of the code should not require any changes to work.
    To infinity and beyond
    Great work! You are now able to create an app that can integrate with an external installation of Grasshopper through a Grasshopper Worker!
    Of course, the journey doesn't end here. Check out some of our other tutorials or go to the next section or try to connect your own Grasshopper script to your VIKTOR app!
