Tutorial - Integrate ETABS and SAP2000
Estimated time: 55 minutes
Difficulty level: Intermediate
  • Introduction
    ETABS and SAP2000 are two of the most commonly used software tools for structural engineering. They offer a range of features for modeling and design, along with a robust API that automates various workflows. In this tutorial, you will learn how to create a VIKTOR web app that integrates these tools behind the scenes. Although this tutorial is written specifically for ETABS, it can easily be modified to use SAP2000.
    Here are the main sections we will cover:
    1. Create a new VIKTOR app.
    2. Create a simple parametric model.
    3. Calculate the reaction loads of your model.
    4. Display the reaction loads in your VIKTOR app.
    Here is a sneak peek at how the app will look: model
    Prerequisites and downloads
    Prerequisites
    • You have installed VIKTOR
    • You have some experience with reading Python code
    • You have some experience with ETABS/SAP2000
    Before using the ETABS API in Python, ensure you have pywin32 and comtypes installed in your Python environment. If they are not installed, you can add them using pip. Open Windows Powershell and run the following command:
    pip install pywin32 comtypes
    Let's create, install and start an empty app. This will be the starting point for the rest of the tutorial. But before we start, make sure to shut down any app that is running (like the demo app) by closing the command-line shell (for example Powershell) or end the process using Ctrl + C.
    1. Open a terminal and run the following command to create the app on the VIKTOR platform and generate the initial code locally:
      viktor-cli create-app "ETABS SAP2000 tutorial" --init --app-type editor
    2. Open the newly created folder in your code editor and run viktor-cli clean-start in the terminal to install dependencies and connect the app to the platform.
    INFO    : Connecting to cloud.viktor.ai...
    INFO :
    INFO :
    Re-starting your app
    • You only need to create an app template and install it once for each new app you want to make.
    • The app will update automatically once you start adding code in app.py, as long as you don't close the terminal or your code editor.
    • Did you close your code editor? Use viktor-cli start to start the app again. No need to install, clear, etc.
    Let's define a simple structure
    To generate a simple moment frame, we use a parametric approach by defining the frame's length and height as variables. The function create_frame_data creates the frame’s topology using nodes and lines to represent its geometry. This approach allows us to generate different configurations by adjusting the length and height values. Additionally, the geometry is saved to a json file each time the function is executed. In the next sections, we will show how this function is used within the Controller class, triggered when new inputs are defined in the Parametrization class. Take a moment to review the following code snippet before continuing with the tutorial.
    import json
    def create_frame_data(length, height):
    nodes = {
    1:{"node_id": 1, "x": 0, "y": 0, "z": 0},
    2:{"node_id": 2, "x": 0, "y": length, "z": 0},
    3:{"node_id": 3, "x": 0, "y": 0, "z": height},
    4:{"node_id": 4, "x": 0, "y": length, "z": height},
    5:{"node_id": 5, "x": length, "y": 0, "z": 0},
    6:{"node_id": 6, "x": length, "y": length, "z": 0},
    7:{"node_id": 7, "x": length, "y": 0, "z": height},
    8:{"node_id": 8, "x": length, "y": length, "z": height},
    lines = {
    1:{"line_id": 1, "node_i": 1, "node_j": 3},
    2:{"line_id": 2, "node_i": 2, "node_j": 4},
    3:{"line_id": 3, "node_i": 3, "node_j": 4},
    4:{"line_id": 4, "node_i": 6, "node_j": 8},
    5:{"line_id": 5, "node_i": 5, "node_j": 7},
    6:{"line_id": 6, "node_i": 3, "node_j": 7},
    7:{"line_id": 7, "node_i": 4, "node_j": 8},
    8:{"line_id": 8, "node_i": 7, "node_j": 8},
    return nodes, lines
    pass
    Let's create the 3D model
    Now that we have a function to generate the topology of our structure, it's time to define the inputs in our Parametrization class and implement the logic to create a 3D model of the frame in a GeometryView. You can refer to the documentation for more details on how to work with 3D geometry in VIKTOR. The resulting code of your app is shown below:
    import json
    nodes = {
    lines = {
    return nodes, lines
    intro = vkt.Text(""" # ETABS Base Reaction App
    Please fill in the following parameters:
    frame_length = vkt.NumberField("Frame Length", min=100, default=4000, suffix="mm")
    frame_height = vkt.NumberField("Frame Height", min=100, default=4000, suffix="mm")
    @vkt.GeometryView("3D Model", duration_guess=1, x_axis_to_right=True)
    def create_render(self, params, **kwargs):
    nodes, lines = create_frame_data(length=params.frame_length, height=params.frame_height)
    sections_group = []
    for line_id, dict_vals in lines.items():
    node_id_i = dict_vals["node_i"]
    node_id_j = dict_vals["node_j"]
    node_i = nodes[node_id_i]
    node_j = nodes[node_id_j]
    point_i = vkt.Point(node_i["x"], node_i["y"], node_i["z"])
    point_j = vkt.Point(node_j["x"], node_j["y"], node_j["z"])
    line_k = vkt.Line(point_i, point_j)
    section_k = vkt.RectangularExtrusion(300, 300, line_k, identifier=str(line_id))
    sections_group.append(section_k)
    return vkt.GeometryResult(geometry=sections_group)
    Great! Now, you can change the dimensions of your frame, and the model will render with the updated geometry. You should see an app like this in your browser:
    model
    However, since you're here to learn how to integrate ETABS or SAP2000, let's move on and start using the CSI API!
    Hands on the ETABS API
    Let's create a new Python file called run_etabs_model.py in the same directory and add a create_etabs_model function. This function contains the logic to create our ETABS model using Python. The first step is to initialize the program with comtypes. Copy the snippet below, and make sure to update the program_path to match your ETABS version. You can run this code in your Python environment, and it will open a blank ETABS model.
    If ETABS is running on a remote server, the program_path needs to match the ETABS location on the server where the worker is running.
    import comtypes.client
    import pythoncom
    import json
    def create_etabs_model():
    # Initialize ETABS model
    program_path=r"C:\Program Files\Computers and Structures\ETABS 22\ETABS.exe"
    pythoncom.CoInitialize()
    try:
    helper = comtypes.client.CreateObject("ETABSv1.Helper")
    helper = helper.QueryInterface(comtypes.gen.ETABSv1.cHelper)
    EtabsEngine = helper.CreateObject(program_path)
    EtabsEngine.ApplicationStart()
    EtabsObject = EtabsEngine.SapModel
    EtabsObject.InitializeNewModel(9) # Set units to mm
    EtabsObject.File.NewBlank()
    finally:
    pythoncom.CoUninitialize()
    if __name__ == "__main__":
    Create the structure in ETABS
    Next, let's extend the create_etabs_model function to add joints, members, and rigid supports. We'll load the nodes and lines geometry from the inputs.json file, then create the nodes and members in ETABS, followed by defining the material properties for the frame. Here's how all this looks in code:
    try:
    finally:
    # Create joints
    input_json = Path.cwd() / "inputs.json" #only works when running python from the working directory!
    with open(input_json) as jsonfile:
    data = json.load(jsonfile)
    nodes, lines = data[:]
    # Create nodes
    for node_id, node in nodes.items():
    ret, _ = EtabsObject.PointObj.AddCartesian(
    node["x"], node["y"], node["z"], " ", str(node_id))
    # Create members
    MATERIAL_CONCRETE = 2
    ret = EtabsObject.PropMaterial.SetMaterial("CONC", MATERIAL_CONCRETE)
    ret = EtabsObject.PropMaterial.SetMPIsotropic("CONC", 30000, 0.2, 0.0000055)
    section_name = "300x300 RC"
    ret = EtabsObject.PropFrame.SetRectangle(section_name, "CONC", 300, 300)
    for line_id, line in lines.items():
    point_i = line["node_i"]
    point_j = line["node_j"]
    ret, _ = EtabsObject.FrameObj.AddByPoint(
    str(point_i), str(point_j), str(line_id), section_name, "Global"
    # Add rigid supports
    list_nodes = [1, 2, 5, 6]
    for node_id in list_nodes:
    ret = EtabsObject.PointObj.SetRestraint(str(node_id), [1, 1, 1, 1, 1, 1])
    EtabsObject.View.RefreshView(0, False)
    Run the model
    Now you can save the model and run the analysis. By default, ETABS creates a load case called Dead, which includes only the self-weight of the structure. After the analysis, we can extract the reaction loads and save the results in a .json file to be used later in our VIKTOR app.
    try:
    finally:
    # Create joints
    # Create nodes
    # Create members
    # Create the model and run the analysis
    file_path = Path.cwd() / "etabsmodel.edb"
    EtabsObject.File.Save(str(file_path))
    EtabsObject.Analyze.RunAnalysis()
    # Get the reaction loads
    load_case = "Dead"
    ret = EtabsObject.Results.Setup.DeselectAllCasesAndCombosForOutput()
    reactions_list = list()
    ret = EtabsObject.Results.Setup.SetCaseSelectedForOutput(load_case)
    for node in list_nodes:
    *_, U1, U2, U3, R1, R2, R3, ret = EtabsObject.Results.JointReact(
    str(node), 0, 0
    reaction = {
    "Node": str(node),
    "LoadCase": load_case,
    "U1": U1[0],
    "U2": U2[0],
    "U3": U3[0],
    "R1": R1[0],
    "R2": R2[0],
    "R3": R3[0],
    reactions_list.append(reaction)
    # Save the output in a JSON
    output = Path.cwd() / "output.json"
    with open(output, "w") as jsonfile:
    json.dump(reactions_list, jsonfile)
    ret = EtabsEngine.ApplicationExit(False)
    return ret
    After running your run_etabs_model.py in your Python environment, you should end up with a model like the following:
    model
    How to connect your VIKTOR app with the CSI API?
    The connection between VIKTOR and SAP2000 or ETABS is managed by a “worker.” A worker is a program that connects the VIKTOR platform to third-party software running outside the platform. You can install the worker on your local machine to test the integration by following this tutorial.
    Let's integrate the worker in our VIKTOR app
    In the Controller of our VIKTOR app, we need to set up the communication with the worker. To call the worker, we use the ETABSAnalysis class, which allows us to send inputs (files and objects) to the worker. In this example, we will send the inputs.json and run_etabs_model.py to be executed in the environment set up for the worker. This environment can be on your own computer or a remote server. When run_etabs_model.py is executed, it will generate the output.json file, and the worker will handle transferring this file from the server environment to our VIKTOR app. Here's how it looks in the code:
    import json
    from io import BytesIO
    nodes = {
    lines = {
    return nodes, lines
    intro = vkt.Text(
    "# ETABS Base Reaction App"
    "\n\n Please fill in the following parameters:"
    sections_group = []
    def run_etabs(self, params, **kwargs):
    nodes, lines = create_frame_data(length=params.frame_length, height= params.frame_height)
    input_json = json.dumps([nodes, lines])
    script_path = Path(__file__).parent / "run_etabs_model.py"
    files = [("inputs.json", BytesIO(bytes(input_json, 'utf8')))]
    etabs_analysis = vkt.etabs.ETABSAnalysis(
    script=vkt.File.from_path(script_path), files=files, output_filenames=["output.json"]
    etabs_analysis.execute(timeout=300)
    output_file = etabs_analysis.get_output_file("output.json", as_file=True)
    And of course, we would like to see the results in a nice table, so we will decorate the previous function with a TableView and post-process the results from the output.json file, as shown below:
    import json
    nodes = {
    lines = {
    return nodes, lines
    intro = vkt.Text(
    sections_group = []
    @vkt.TableView("Base Reactions",duration_guess=10, update_label="Run ETABS analysis")
    reactions = json.loads(output_file.getvalue())
    data = []
    for reaction in reactions:
    data.append([
    reaction.get("Node", 0),
    reaction.get("LoadCase", "Dead"),
    round(reaction.get("U1", 0), 0),
    round(reaction.get("U2", 0), 0),
    round(reaction.get("U3", 0), 0)
    return vkt.TableResult(
    data,
    row_headers=["Sup 1","Sup 2","Sup 3","Sup 4"],
    column_headers=["Node", "Load Case","U1[N]", "U2[N]", "U3[N]"],
    Now you're ready to test your app. Make sure your worker is running, then try generating the model. After the analysis, your app should look like this:
    model
    What about SAP2000?
    You can integrate SAP2000 in the same way we did for ETABS. All you need to do is change the program path and the helper, as shown below.
    import pythoncom
    def initialize_sap2000(
    program_path=r"C:\Program Files\Computers and Structures\SAP2000 25\SAP2000.exe",
    try:
    helper = comtypes.client.CreateObject("SAP2000v1.Helper")
    helper = helper.QueryInterface(comtypes.gen.SAP2000v1.cHelper)
    SapEngine = helper.CreateObject(program_path)
    SapEngine.ApplicationStart()
    SapObject = SapEngine.SapModel
    SapObject.InitializeNewModel()
    SapObject.File.NewBlank()
    return SapObject, SapEngine
    finally:
    Your turn to build
    You now have everything you need to start building powerful applications that integrate ETABS and SAP2000 into your VIKTOR apps. But the journey doesn’t end here, you can explore our other tutorials or try integrating your own ETABS or SAP2000 model.
