Tutorial - Post-process STAAD.Pro data
Level: Beginners
Time: 20 min
Prerequisites:
  • You have an account and completed the installation process. No account? Get one here
  • You have some experience with reading Python code
  • In this tutorial, you will build a VIKTOR app to process and visualize outputs from STAAD.PRO. You’ll learn how to export these outputs from STAAD.PRO into a VIKTOR web app and post-process design ratios for various cross-sections. Filtering, grouping, and visualizing these design ratio outputs is not possible directly in STAAD.PRO, and there is no native way to export these results directly to Excel. This tutorial will guide you through overcoming these limitations while exploring the powerful tools and building blocks that VIKTOR and Pandas provide.
    Here is what we'll cover:
    By the end of this tutorial, you will be able to generate a table with a heatmap displaying design ratios for your structure by filtering or grouping specific cross-sections. You will also have the opportunity to test this using your own data by following the steps outlined in the final section of the tutorial. This will help you gain valuable insights from your results and effectively share them with your clients and team.
    final app
    1. Basic setup
    Let’s create, install, and start a blank app template. We’ll use this blank template as the base for our design ratios app. Before we begin, ensure that any running app (like the demo app) is stopped. You can do this by closing the command-line shell (e.g., PowerShell) or by canceling the process with Ctrl + C.
    1. Open a terminal and run the following command to create the app on the VIKTOR platform and generate the initial code locally:
      viktor-cli create-app "STAAD data tutorial" --init --app-type editor
    2. Open the newly created folder in your code editor and run viktor-cli clean-start in the terminal to install dependencies and connect the app to the platform.
    INFO    : Connecting to cloud.viktor.ai...
    INFO : Connection is established:
    INFO :
    INFO : https://cloud.viktor.ai/workspaces/XXX/app <--- navigate here to find your app
    INFO :
    INFO : The connection can be closed using Ctrl+C
    INFO : App is ready
    RE-STARTING YOUR APP
    You only need to create an app template and install it once for each new app you want to make. The app will update automatically once you start adding code in app.py, as long as you don't close the terminal or your code editor. Did you close your code editor? Use viktor-cli start to start the app again. No need to install, clear, etc.
    Adding useful Python packages
    We want to use Pandas and VIKTOR as our only dependencies in this app. Open requirements.txt and add pandas under your viktor version (do not change that line):
    viktor==X.X.X  # Don’t modify this line
    pandas
    Next, close the connection to your app in the terminal (if the app has been connected automatically). You can do this by using Ctrl+C. Open a new terminal and install the new dependencies (like pandas) in your Python environment by running this command:
    viktor-cli install
    And after that, connect your app to the VIKTOR platform again:
    Keep the terminal open, as closing it will disconnect your app.
    2. Creating the structure of our app
    In this step, we will create the structure of our app by organizing it into steps using vkt.Step. This will help us separate the application into inputs and outputs. In the first step, we input the data coming from STAAD.PRO with the vkt.Table, and in the second step, we filter and group the results with a TableView.
    Later, we will add a TableView and the logic for the filtering and grouping components on step 2.
    Feel free to copy and paste the highlighted lines of code into app.py, save the file, and refresh the app in the browser. You should now see the input fields you just added to the code.
    step_1 = vkt.Step("Step 1 - Input Your Data!")
    step_1.intro = vkt.Text("""
    # STAAD Design Ratio Analyzer
    This app allows you to visualize a heat map from your STAAD.PRO model results.
    You can filter and group them based on cross sections and visualize how they are distributed.""")
    step_1.table_input = vkt.Text("""
    ## 1.0 Create the Input Table!
    Paste the design ratio data from your STAAD.PRO model!""")
    step_1.table = vkt.Table("### Beam Design Analysis")
    step_1.table.col_beam = vkt.TextField("Beam")
    step_1.table.col_analysis_property = vkt.TextField("Analysis Property")
    step_1.table.col_design_property = vkt.TextField("Design Property")
    step_1.table.col_actual_ratio = vkt.NumberField("Actual Ratio")
    step_1.table.col_allowable_ratio = vkt.NumberField("Allowable Ratio")
    step_1.table.col_normalized_ratio = vkt.NumberField("Normalized Ratio")
    step_1.table.col_clause = vkt.TextField("Clause")
    step_1.table.col_load_case = vkt.TextField("L/C")
    step_1.table.col_ax = vkt.TextField("Ax in²")
    step_1.table.col_iz = vkt.TextField("Iz in⁴")
    step_1.table.col_iy = vkt.TextField("Iy in⁴")
    step_1.table.col_ix = vkt.TextField("Ix in⁴")
    step_2 = vkt.Step("Step 2 - Post-Processing")
    step_2.process = vkt.Text("""
    ## 2.0 Filter and Group
    Group or filter by a specific cross section.
    Use the options below to customize your view.
    If you want to list all cross-sections after selecting one, you can select the "All" option!
    step_2.group = vkt.BooleanField("### Group by Cross-Section")
    step_2.ln_break = vkt.LineBreak()
    step_2.cross_section = vkt.OptionField(
    "### Filter by Cross-Section", options=["Empty Options"]
    parametrization = Parametrization()
    How this works
    • We organized our app into two steps using vkt.Step:
      • Step 1 is for inputting data. We added introductory text using vkt.Text and created a table called step_1.table using vkt.Table. This table replicates the columns from the design ratio table in STAAD.PRO.
      • Step 2 is for post-processing. This step includes the following features:
        • Filtering:
          • We use vkt.OptionField to show a list of cross-sections that the user can select.
          • Only design ratios of the selected cross-section will be displayed.
        • Grouping:
          • We use vkt.BooleanField to let the user group the design ratios by cross-section.
          • When grouping is enabled, the app displays only the maximum design ratio for each cross-section.
    • The Controller class sets parametrization = Parametrization() to link our parametrization to the controller.
    The result should look like the image below. Now that the inputs are ready, we will move on to process the STAAD.PRO data.
    Create app
    3. Process the STAAD.PRO data
    Sample STAAD.PRO design ratio data
    For this tutorial, you can use this in TXT format, which you can copy and paste into our vkt.Table. However, you can use your own design ratio data from STAAD.PRO. At the end of this tutorial, we will guide you on how to get this data from STAAD.PRO.
    info
    The last section of this tutorial shows how to get this data from STAAD.PRO. For now, you can use the sample .TXT file to complete and test the app!
    Processing the STAAD.PRO data
    The next step is to process the data from the vkt.Table. It's a good idea to do this processing in a separate function, which we'll name generate_dataframe. This function will convert the table data into a Pandas DataFrame and rename the columns for easier access.
    Below is the logic in the code, along with a breakdown. Add the highlighted lines of code to app.py and save the file.
    import pandas as pd
    def generate_dataframe(table_data):
    df = pd.DataFrame([dict(item) for item in table_data])
    df.rename(
    columns={
    "col_beam": "Beam",
    "col_analysis_property": "Analysis Property",
    "col_design_property": "Design Property",
    "col_actual_ratio": "Actual Ratio",
    "col_allowable_ratio": "Allowable Ratio",
    "col_normalized_ratio": "Normalized Ratio (Actual/Allowable)",
    "col_clause": "Clause",
    "col_load_case": "L/C",
    "col_ax": "Ax in²",
    "col_iz": "Iz in⁴",
    "col_iy": "Iy in⁴",
    "col_ix": "Ix in⁴",
    inplace=True,
    return df
    How this works
    • At the top of the file, we import pandas, which we'll use to manipulate the data.
    • The function generate_dataframe converts the table data from the Parametrization into a DataFrame and renames the columns to more readable names.
    • This function returns the DataFrame, which will be used later to process and visualize the data.
    4. Allow user selection of cross-sections
    Now that we have implemented the generate_dataframe function, we can use the resulting DataFrame to create a list of cross sections. To do this, we can get the unique cross-section names from the "Design Property" column and convert them into a list. This list will be used in our OptionField. You can update the code as shown in the code snippet below!
    import pandas as pd
    df.rename(
    columns={
    "col_beam": "Beam",
    "col_ax": "Ax in²",
    "col_iz": "Iz in⁴",
    "col_iy": "Iy in⁴",
    "col_ix": "Ix in⁴",
    inplace=True,
    return df
    def get_cross_sections(params, **kwargs):
    if params.step_1.table:
    df = generate_dataframe(params.step_1.table)
    secs = df["Design Property"].unique().tolist()
    secs.append("All")
    return secs
    return ["No data available! Please add table input."]
    "### Filter by Cross-Section", options=get_cross_sections
    How this works
    • The get_cross_sections function reads the DataFrame and extracts the unique values from the 'Design Property' column.
    • These unique cross-sections are returned as a list to be used as options in the cross_section OptionField. We also append "All" to the list to allow viewing all cross sections.
    • By setting options=get_cross_sections in the OptionField, we fill the field with the cross sections from the data (if there is data input).
    5. Visualize design ratios with VIKTOR
    After the user inputs data into the vkt.Table, we want to create clear visualizations and add functionality to the vkt.BooleanField and vkt.OptionField for grouping and filtering.
    To do this, we will add a TableView that shows the design ratios in a table, sorted and colored based on their values. The logic for this will be implemented in the table_design_ratios method inside the Controller class.
    In addition, we will use a complementary function called get_cell_color to assign a color based on the design ratio values. This will allow us to create a heatmap within the table.
    Copy the highlighted piece of code and add it to app.py.
    import pandas as pd
    df.rename(
    columns={
    "col_beam": "Beam",
    "col_ax": "Ax in²",
    "col_iz": "Iz in⁴",
    "col_iy": "Iy in⁴",
    "col_ix": "Ix in⁴",
    inplace=True,
    return df
    secs.append("All")
    return secs
    step_2 = vkt.Step("Step 2 - Post-Processing", views=["table_design_ratios"])
    @vkt.TableView(label="Design Ratios by Cross Section")
    def table_design_ratios(self, params, **kwargs):
    if not params.step_1.table or len(params.step_1.table) == 0:
    return vkt.TableResult([["No data available! Please add table input."]])
    # Group or filter the data based on user selection
    if params.step_2.group:
    # For each cross section, get the row with the maximum normalized ratio
    df = df.loc[
    df.groupby("Design Property")[
    ].idxmax()
    ].reset_index(drop=True)
    if params.step_2.cross_section and params.step_2.cross_section != "All":
    df = df[df["Design Property"] == params.step_2.cross_section]
    # Drop unnecessary columns
    df.drop(
    ["Ax in²", "Iz in⁴", "Iy in⁴", "Ix in⁴", "Analysis Property", "Clause"],
    axis=1,
    inplace=True,
    # Sort the DataFrame by Normalized Ratio in descending order
    df.sort_values(
    by="Normalized Ratio (Actual/Allowable)", ascending=False, inplace=True
    # Create table data with color-coded cells
    data = []
    for _, row in df.iterrows():
    ratio = row["Normalized Ratio (Actual/Allowable)"]
    color = self.get_cell_color(ratio)
    row_data = row.tolist()
    row_data[4] = vkt.TableCell(ratio, background_color=color)
    data.append(row_data)
    data, column_headers=df.columns.tolist(), enable_sorting_and_filtering=True
    def get_cell_color(self, ratio):
    if ratio >= 1:
    return vkt.Color(210, 0, 0) # Red
    elif ratio >= 0.85:
    return vkt.Color(255, 165, 0) # Orange
    else:
    return vkt.Color(0, 210, 0) # Green
    How this works
    • We added the table_design_ratios method decorated with @vkt.TableView, which returns a TableResult to be displayed in the app.
    • We specified views=["table_design_ratios"] in step_2, so the TableView will appear in Step 2.
    • We check if there's data available; if not, we return a message indicating that to the user.
    • Depending on the user's selection of group and cross_section, we group or filter the DataFrame.
      • If group is selected, we group the data by "Design Property" and keep the row with the maximum "Normalized Ratio (Actual/Allowable)" for each group.
      • If a cross_section is selected and it's not "All", we filter the DataFrame to only include that cross-section.
    • We drop unnecessary columns to keep the table clean.
    • We sort the DataFrame by "Normalized Ratio (Actual/Allowable)" in descending order.
    • For each row, we create a TableCell for the "Normalized Ratio" column, setting the background color based on the value using the get_cell_color function.
    • The get_cell_color function determines the color based on the ratio value:
      • Ratios >= 1 are colored red (overutilized)
      • Ratios >= 0.85 and < 1 are colored orange (approaching maximum capacity)
      • Ratios < 0.85 are colored green (underutilized)
    The resulting app
    Refresh your app in the browser. You will now see the table view appear in Step 2 of your app. For testing, feel free to copy the rows of the TXT file from section 3, then create a new row in the table. Click the top-left checkbox, press Ctrl + V, and you will see your rows being populated. After that, you can choose to group or filter the results by cross-section and analyze them.
    Create app
    Ensure that there are no empty rows in the vkt.Table; otherwise, the app will complain. You can right-click on an empty row and delete it.
    You can use the "Group by Cross-Section" toggle to view the maximum design ratios for each cross-section. Alternatively, you can use the "Filter by Cross-Section" dropdown to focus on a specific cross-section and see how its design ratios are distributed. This provides flexibility in analyzing the data based on your needs.
    Complete code
    Were you able to do everything in this tutorial without error? If not, you can always look at the full code:
    import pandas as pd
    df.rename(
    columns={
    "col_beam": "Beam",
    "col_ax": "Ax in²",
    "col_iz": "Iz in⁴",
    "col_iy": "Iy in⁴",
    "col_ix": "Ix in⁴",
    inplace=True,
    return df
    secs.append("All")
    return secs
    df = df.loc[
    ].idxmax()
    df.drop(
    axis=1,
    inplace=True,
    df.sort_values(
    data = []
    if ratio >= 1:
    elif ratio >= 0.85:
    else:
    Export your own results from STAAD.PRO
    To export the design ratios from your STAAD.PRO app, first run your analysis and design check. Then, right-click > Tables > Design Results, and simply copy and paste the data into the vkt.Table component in the app. Make sure there are no empty rows, and you are all set!
    You can see how this process works in the animation below.
    Export data
    What's next?
    In this tutorial, you learned how to post-process results exported from STAAD.PRO. Your next goal could be to implement automation using the STAAD.PRO API from your VIKTOR app. To achieve this, the best place to start is the following tutorial.
