Creating an editor-type app
In this tutorial we will create an editor-only application, that can be used to visualize world population and life expectancy data in a few different ways:
- bar chart of the Netherlands
- animated scatter plot per continent
- world map surface plot
The end result can be downloaded here.
For more examples of applications, please visit the sample apps
Creating an empty app
- Go to the App store in your VIKTOR environment to create a new app. After clicking 'Create app' choose the option 'Create blank app' and enter a name and description of your choice. Submit the form by clicking 'Create and setup'.
- Select 'Editor' as app type and click 'Next'.
- Now follow the instructions to run the
quickstartcommand to download the empty app template. After entering the command click 'I have run the command' to continue. The CLI will ask you to select your code editor of choice. Use the arrows and press enter to select a code editor. The app will now open in your code editor of choice.
INFO :
INFO :
- You only need create an app template and install it once for each new app you want to make.
Folder structure
editor-tutorial
├── app.py
├── CHANGELOG.md
├── README.md
├── tests
│ └── __init__.py
Note that the app type ('editor') has been defined in viktor.config.toml:
Dependencies
Navigate to the newly created folder and open requirements.txt and add plotly as additional requirement. We will
use this package to create the (interactive) visualizations.
viktor==X.X.X
plotly
Installation
After adding the additional requirement the app needs to be installed again. Navigate to your terminal in the code editor, close the connection using Ctrl+C and enter the following command:
viktor-cli install
And afterwards:
Go to your browser and refresh the page to verify that the app is installed and running as expected. You should see the app's editor, which is currently a blank page.
If you see the "Workspaces" menu upon logging in, click the "Open" button on the "Development" workspace. After opening, you will be redirected to the app's editor.
Defining the editor (input / output)
Open app.py and replace it with the following code:
import plotly.express as px
graph = vkt.OptionField(
"Life expectancy:",
options=["The Netherlands", "Continents", "Global"],
default="Continents",
variant="radio",
flex=100
parametrization = Parametrization(width=20)
@vkt.PlotlyView("Life Expectancy")
def plotly_view(self, params, **kwargs):
df = px.data.gapminder()
if params.graph == 'The Netherlands':
data = df.query("country == 'Netherlands' ")
fig = px.bar(data, x='year', y='pop', color='lifeExp')
elif params.graph == 'Continents':
fig = px.scatter(
df, x="gdpPercap", y="lifeExp", animation_frame="year", animation_group="country",
size="pop", color="continent", hover_name="country", facet_col="continent",
log_x=True, size_max=75, range_x=[100, 100000], range_y=[25, 90]
elif params.graph == 'Global':
fig = px.choropleth(
df, locations='iso_alpha', color='lifeExp', hover_name='country',
animation_frame='year', color_continuous_scale=px.colors.sequential.Plasma,
projection='natural earth'
else:
raise NotImplementedError
return vkt.PlotlyResult(fig)
In your browser, refresh the page to reload the editor. On the left side, you will now see radio buttons with the defined options. Go ahead and select another option and see how it influences the results on the right-hand side.
