Autodesk files
The AutodeskFileField lets a user select a single file from Autodesk cloud storage. For the AutodeskView, an access token is required; therefore, an Autodesk Platform Services integration must be set up first, and the integration name must be passed in the field.
autodesk_file = vkt.AutodeskFileField(
"Select a file",
oauth2_integration="aps-integration-1",
In alphabetical order:
- description, add a tooltip with extra information
vkt.AutodeskFileField(..., description="This field represents the project model")
- file_types, optional restriction of file types, case insensitive
vkt.AutodeskFileField(..., file_types=[".rvt"])
- flex, width of the field between 0 and 100, default is 33
vkt.AutodeskFileField(..., flex=50)
- name, defines the position of the parameter in
params
vkt.AutodeskFileField(..., name="f") # obtained using params.f
- oauth2_integration, required integration name for Autodesk authentication
vkt.AutodeskFileField(..., oauth2_integration="aps-integration-1")
- visible, control visibility based on other input fields
vkt.AutodeskFileField(..., visible=vkt.Lookup("another_field"))
See 'Hide a field' for elaborate examples.
Using AutodeskFileField in a Controller
AutodeskFile: when a file is selected- None: when empty
The following sections show how to use these methods and attributes to download the raw file and to display the model in VIKTOR apps.
Downloading a model file
To download a BIM model, you start with the AutodeskFile and follow a clear sequence. First, use the integration to obtain a token. Then request the latest AutodeskFileVersion, read its attributes to get the file metadata, and finally download the file. The code below demonstrates this flow:
- Obtain an access token with
OAuth2Integration. - Use
get_latest_version(token)on theAutodeskFileto retrieve the latest version. - Access metadata through
version.attributes. - (Optional) Get the model identifier with
version.urn. - Call
version.get_file()to get the file content and return it in aDownloadResult..
"Select a file",
download = vkt.DownloadButton("Download BIM model", method="download_model")
def download_model(self, params, **kwargs):
if not params.autodesk_file:
raise vkt.UserError("Select a file in the Autodesk field")
integration = vkt.external.OAuth2Integration("aps-integration-1")
token = integration.get_access_token()
# Latest version and key metadata
version = params.autodesk_file.get_latest_version(token)
attrs = version.attributes # dict
display_name = attrs.get("displayName", "model")
urn = version.urn
vkt.UserMessage.info(f"Downloading BIM file, urn={urn}")
file_bytes = version.get_file()
return vkt.DownloadResult(file_content=file_bytes, file_name=display_name)
AutodeskFileVersion attributes
The AutodeskFileVersion.attributes property returns a dict with the file’s metadata. Common attributes include displayName (file name), versionNumber, createTime and createUserName, lastModifiedTime and lastModifiedUserName, fileType, storageSize, processing and review states such as processState, extractionState, splittingState, reviewState, and revision identifiers like revisionDisplayLabel and sourceFileName.
Displaying a model file
The AutodeskFile can be passed directly to a AutodeskResult to display the model in an AutodeskView. Refer to the complete documentation for sample code.
Miscellaneous file properties
There are various other file properties and methods:
AutodeskFile
urn(≥ v14.26.0): Unique resource id of this file.project_id(≥ v14.26.0): URN of the project this file belongs to.get_hub_id(access_token)( ≥ v14.26.0): Obtain the hub this file belongs to.get_region(access_token)(≥ v14.26.0): Obtain the region of the hub this file belongs to.get_aec_data_model_element_group_id(access_token)(≥ v14.26.0): Obtain the AEC Data Model ElementGroup ID associated with this file.
AutodeskFileVersion
storage_url(≥ v14.26.0): Storage url of this version of the file.
