Show a summary
A Summary is used to store important parameters of an entity. This enables
easy sorting and comparing of different entities in an overview. A Summary can be defined per entity type
(controller), and is optional. A summary can have a maximum of 6 summary items.
Implementation: from parametrization
One source of summary items is the parametrization. You can point to a field in the parametrization and the value of this field will be shown in the summary.
The following fields can be used in a summary:
Adding a summary is done with the following steps:
Add a controller
summaryattribute:import viktor as vkt
summary = vkt.Summary()
Add a SummaryItem and link to the parametrization:
item_1=vkt.SummaryItem('Length', float, 'parametrization', 'geometry.input.length', prefix='m')
Above example assumes the following parametrization:
geometry = vkt.Tab(...)
geometry.input = vkt.Section(...)
geometry.input.length = vkt.NumberField(...)
Implementation: from results
When a view contains data (e.g. DataView, GeometryAndDataView, etc.), that data can be used in the summary.
SummaryItems can only be obtained from a "quick" view (i.e. without manual update button).
Add a controller
Create a
DataViewwhich returns the result(s) that should be shown on the summary:import viktor as vkt
@vkt.DataView("Cost")
def calculate_cost(self, params, **kwargs):
# app specific cost calculation
material_cost = ...
total_cost = material_cost + ...
data = vkt.DataGroup(
total_cost=vkt.DataItem('Total cost', total_cost, prefix='€', subgroup=vkt.DataGroup(
material_cost=vkt.DataItem('Material', material_cost, prefix='€')
return vkt.DataResult(data) -
Add a
SummaryItemand link to theDataItem(in this example the material cost):import viktor as vkt
summary = vkt.Summary(item_1=vkt.SummaryItem('Materials', float, 'calculate_cost', 'total_cost.material_cost', prefix='€'))
Keep in mind that when creating a DataGroup you can pass a list or dict of data items. When you use a list however,
the items can not be used in the Summary, because there is no keyword that functions as link between the result and
the summary.
Prefix/suffix
The prefix/suffix that is defined on the SummaryItem is stored in the database and has to be static, such that it can
be used to for example sort entities of a certain entity type. This means that there cannot be any inconsistency
between prefix/suffix definitions of an entity type and they should not be changed.
The prefix/suffix of a DataItem however can in most cases be dynamic. A good example is when the result of an
analysis is a reaction force in Newtons. Since this result is dynamic and can potentially be extremely large, a user
could find it more convenient to show this result in kN. This unit can switch with every call and this dynamic behavior
holds for all DataItems. However, when the result is used in the Summary, the prefix/suffix of the DataItem
should be equal to the prefix/suffix of the SummaryItem and static as explained above.
