Hide a view
New in v14.22.0
A view can be hidden (or shown) based on other input fields by assigning a callback function to the visible argument
within the view. The callback function needs to return a boolean:
def get_visibility(params, **kwargs):
return params.param_x
@vkt.TableView("Results", visible=get_visibility)
def my_table_view(self, params, **kwargs):
If a Page or Step is used, views
will only be visible in the editor if they are both visible and defined in the page/step's views.
When the visibility depends on data of another entity, the entity_id can be used to navigate and obtain data using
the SDK API.
Upon evaluation of the visibility constraint, the platform passes the params, entity_id, entity_name, and
workspace_id to the callback function. All individual kwargs can be added explicitly in the signature if desired:
def get_visibility(params, entity_id, entity_name, workspace_id, **kwargs):
