Action buttons
Action buttons can be added to a parametrization to enable the user to perform certain actions. All action buttons have
a (required) method argument that represents the name of the method on the corresponding
controller class. Various buttons exist
for different type of actions, which all require a different return on the corresponding button method.
ActionButton - action without result
To perform an action without returning any result, the ActionButton can be used:
button = vkt.ActionButton('ActionButton', method='perform_action')
In alphabetical order:
button = vkt.ActionButton('ActionButton', method='perform_action', description="This field represents the ...") -
flex: the width of the field between 0 and 100 (default=33)
button = vkt.ActionButton('ActionButton', method='perform_action', flex=50) -
interaction: enable view interaction
'ActionButton',
interaction=MapSelectInteraction('my_map_view', selection=['points'])
longpoll: set to True if the triggered method cannot be completed within the timeout limit (15s)
button = vkt.ActionButton('ActionButton', method='perform_action', longpoll=True) -
method: controller method that will be triggered
button = vkt.ActionButton('ActionButton', method='perform_action') -
button = vkt.ActionButton('ActionButton', method='perform_action', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
The button method is expected to return nothing (None):
def perform_action(self, params, **kwargs):
# no return
DownloadButton - download a file
To perform an action that returns a file download, the DownloadButton can be used.
button = vkt.DownloadButton('DownloadButton', method='perform_download')
button = vkt.DownloadButton('DownloadButton', method='perform_download', description="This field represents the ...") -
button = vkt.DownloadButton('DownloadButton', method='perform_download', flex=50) -
'DownloadButton',
button = vkt.DownloadButton('DownloadButton', method='perform_download', longpoll=True) -
button = vkt.DownloadButton('DownloadButton', method='perform_download') -
button = vkt.DownloadButton('DownloadButton', method='perform_download', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
The button method is expected to return a DownloadResult:
def perform_download(self, params, **kwargs):
return vkt.DownloadResult(...)
For more information, refer to the guide on how to handle downloading of files.
SetParamsButton - set params action
To set the params by means of a button click, the SetParamsButton can be used.
button = vkt.SetParamsButton('SetParamsButton', method='set_params')
button = vkt.SetParamsButton('SetParamsButton', method='set_params', description="This field represents the ...") -
button = vkt.SetParamsButton('SetParamsButton', method='set_params', flex=50) -
'SetParamsButton',
button = vkt.SetParamsButton('SetParamsButton', method='set_params', longpoll=True) -
button = vkt.SetParamsButton('SetParamsButton', method='set_params') -
button = vkt.SetParamsButton('SetParamsButton', method='set_params', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
The button method is expected to return a SetParamsResult:
def set_params(self, params, **kwargs):
return vkt.SetParamsResult(...)
For more information, refer to the guide on how to set params using a button.
OptimizationButton - optimization action
The OptimizationButton can be used to perform an optimization routine.
button = vkt.OptimizationButton('OptimizationButton', method='perform_optimization')
button = vkt.OptimizationButton('OptimizationButton', method='perform_optimization', description="This field represents the ...") -
button = vkt.OptimizationButton('OptimizationButton', method='perform_optimization', flex=50) -
button = vkt.OptimizationButton('OptimizationButton', method='perform_optimization', longpoll=True) -
button = vkt.OptimizationButton('OptimizationButton', method='perform_optimization') -
button = vkt.OptimizationButton('OptimizationButton', method='perform_optimization', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
The button method is expected to return a OptimizationResult:
def perform_optimization(self, params, **kwargs):
return vkt.OptimizationResult(...)
For more information, refer to the guide on how to perform an optimization routine.
