User input, fields and buttons
The parametrization is built up by means of input fields that can be filled in and/or buttons that can be clicked by the user.
Input fields
Different types of input fields can be used, For each input field, arguments can be specified to set specific options
and/or constraints such as the default, minimum, or maximum value. See Field for
all possible options.
The following input fields are available:
Numeric input
Decimal number
Numbers with decimals can be specified using a NumberField
Slider
Slider is a visual variant of the NumberField
Integer
The IntegerField can contain integers only
Textual input
Short text
Short text can be specified in a TextField
Long text
Long text can be specified in a TextAreaField
Options & selections
Single option
A single option can be selected in an OptionField
Radio button
An OptionField can be visualized as a radio button
Radio button (horizontal)
An OptionField can also be visualized as a horizontal radio button
Autocomplete
Filter options through typing using an AutocompleteField
Multi-select
Select multiple items from a list using a MultiSelectField
Entity selection
Select single child
Select a single child entity using a ChildEntityOptionField
Select children
Select from a list of child entities using a ChildEntityMultiSelectField
Select single sibling
Select a single sibling entity using a SiblingEntityOptionField
Select siblings
Select from a list of sibling entities using a SiblingEntityMultiSelectField
Select generic entity
Select a single generic entity using an EntityOptionField
Select generic entities
Select from a list of generic entities using an EntityMultiSelectField
Geometry selection
Select a geometry
Select a geometry in a Geometry or IFCView using a GeometrySelectField
Select multiple geometries
Select multiple geometries in a Geometry or IFCView using a GeometryMultiSelectField
Map features
Define a point
Define a geo-point on a MapView using a GeoPointField
Define a polyline
Define a geo-polyline on a MapView using a GeoPolylineField
Define a polygon
Define a geo-polygon on a MapView using a GeoPolygonField
File upload
Upload single file
Upload a single file using a FileField
Upload multiple files
Upload multiple files at once using a MultiFileField
Autodesk files
Select an Autodesk file
Select an Autodesk file from Autodesk cloud storage
Other
Select a date
Pick a date on a calendar using a DateField
Toggle button
Switch on/off using a BooleanField
Store JSON data
Store hidden JSON data on a HiddenField
Line break
Style your editor by manually arrange fields using a LineBreak
Tables & arrays
If the user must be able to make a dynamic number of objects sharing the same properties, tables or arrays can be used.
Table
Draw a table consisting of rows and columns using Table
Array
Bundle fields in rows and let the user add rows using a DynamicArray
Action buttons
In addition to the input fields, action buttons can be added to the parametrization to enable user actions. The following table gives an overview of all action buttons:
Action without result
Perform an action without returning any result using an ActionButton
File download
Perform an action that returns a file download using a DownloadButton
Set params
Set params by means of a button click using a SetParamsButton
Optimization routine
Perform an optimization routine using an OptimizationButton
Read-only fields
The fields below can be used to guide users by providing more context, without the user being able to edit the values.
Show output
Show a (dynamic) value using an OutputField
Static text
Show a static text using Text
Static image
Show a static image using Image
LLM chat
Chat
Enable the potential of LLM in your app
