Upload files
FileField - upload a file
The FileField lets the user upload a single file. Explicit permission for certain file types can optionally be set
using the file_types argument. The max size in bytes of the file to be uploaded can be set with max_size.
file = vkt.FileField('Upload a file')
FileResourceobject: when a file is selected (see uploading files for an example of usage)None: when empty
In alphabetical order:
file = vkt.FileField('Upload a file', description="This field represents the ...") -
file_types: optional restriction of file type(s) (case-insensitive)
file = vkt.FileField('Upload a file', file_types=[".png", ".jpg", ".jpeg"]) -
flex: the width of the field between 0 and 100 (default=33)
file = vkt.FileField('Upload a file', flex=50) -
max_size: optional restriction on file size in bytes (e.g. 10_000_000 = 10 MB)
file = vkt.FileField('Upload a file', max_size=10_000_000) -
name: defines the position of the parameter in the params
file = vkt.FileField('Upload a file', name="f") # obtained using params.f -
file = vkt.FileField('Upload a file', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
MultiFileField - upload multiple files
If multiple files need to be uploaded at the same time, the MultiFileField can be used.
files = vkt.MultiFileField('Upload Multiple Files')
- list of
FileResourceobjects: when a file is selected (see uploading files for an example of usage) - empty list when empty
files = vkt.MultiFileField('Upload Multiple Files', description="This field represents the ...") -
files = vkt.MultiFileField('Upload Multiple Files', file_types=[".png", ".jpg", ".jpeg"]) -
files = vkt.MultiFileField('Upload Multiple Files', flex=50) -
files = vkt.MultiFileField('Upload Multiple Files', max_size=10_000_000) -
files = vkt.MultiFileField('Upload Multiple Files', name="f") # obtained using params.f -
files = vkt.MultiFileField('Upload Multiple Files', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
Autodesk files
Files residing on Autodesk cloud storage do not have to be downloaded and uploaded to VIKTOR, you can use the AutodeskFileField to reference a file on cloud directly instead.
