Textual input
TextField - short texts
A TextField is a simple textual input field.
text = vkt.TextField('This is a TextField')
str: when user inputs a text (e.g. "some text")- empty string when empty
In alphabetical order:
default: a default value will be prefilled
text = vkt.TextField('This is a TextField', default="John Doe") -
text = vkt.TextField('This is a TextField', description="This input represents the ...") -
flex: the width of the field between 0 and 100 (default=33)
text = vkt.TextField('This is a TextField', flex=50) -
name: defines the position of the parameter in the params
text = vkt.TextField('This is a TextField', name="t") # obtained using params.t -
prefix: a prefix will be put in front of the ui name
text = vkt.TextField('This is a TextField', prefix="..") -
suffix: a suffix will be placed behind the ui name
text = vkt.TextField('This is a TextField', suffix="..") -
text = vkt.TextField('This is a TextField', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
TextAreaField - longer texts
For lengthier inputs, the TextAreaField can be used.
text = vkt.TextAreaField('This is a TextAreaField')
str: when user inputs a text (e.g. "some very very very ... long text")- empty string when empty
text = vkt.TextAreaField('This is a TextAreaField', default="Multiple lines \n are possible") -
text = vkt.TextAreaField('This is a TextAreaField', description="This input represents the ...") -
flex: the width of the field between 0 and 100 (default=100)
text = vkt.TextAreaField('This is a TextAreaField', flex=50) -
text = vkt.TextAreaField('This is a TextAreaField', name="t") # obtained using params.t -
text = vkt.TextAreaField('This is a TextAreaField', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
Text - static text blocks
For more information on how to add a static text to the parametrization, that cannot be modified by the user, see
Text. There is no value associated with an Text field within the
params.
