Other fields
Reference
BooleanField - toggle true / false​
The BooleanField acts as a toggle button which can be either True or False.
is_true = vkt.BooleanField('False / True')
  • True: when toggled true
  • False: when toggled false
In alphabetical order:
  • default: a default value will be prefilled
    is_true = vkt.BooleanField('False / True', default=True)
  • description: add a tooltip with additional information
    is_true = vkt.BooleanField('False / True', description="This field represents the ...")
  • flex: the width of the field between 0 and 100 (default=33)
    is_true = vkt.BooleanField('False / True', flex=50)
  • name: defines the position of the parameter in the params
    is_true = vkt.BooleanField('False / True', name="b")  # obtained using params.b
  • visible: can be used when the visibility depends on other input fields
    is_true = vkt.BooleanField('False / True', visible=vkt.Lookup("another_field"))
    See 'Hide a field' for elaborate examples.
ColorField - select a color​
New in v14.0.0
The ColorField enables a user to select a color from a color palette.
color = vkt.ColorField('Pick a color')
  • Color object: when user selects a color
  • None: when empty
    color = vkt.ColorField('Pick a color', default=vkt.Color.red())
    color = vkt.ColorField('Pick a color', description="This field represents the ...")
    color = vkt.ColorField('Pick a color', flex=50)
    color = vkt.ColorField('Pick a color', name="c")  # obtained using params.c
    color = vkt.ColorField('Pick a color', visible=vkt.Lookup("another_field"))
DateField - select a date​
The DateField enables a user to select a date on a calendar.
date = vkt.DateField('Pick a date')
  • datetime.date object: when user selects a data
  • None: when empty
    date = vkt.DateField('Pick a date', default=datetime.date(2021, 3, 14))
    date = vkt.DateField('Pick a date', description="This field represents the ...")
    date = vkt.DateField('Pick a date', flex=50)
    date = vkt.DateField('Pick a date', name="d")  # obtained using params.d
    date = vkt.DateField('Pick a date', visible=vkt.Lookup("another_field"))
HiddenField - store JSON data​
The purpose of the HiddenField is to store JSON-type data in the params, without showing this information to the user in the editor. For example, when doing upload file processing.
json_data = vkt.HiddenField('')
caution
Use the HiddenField with moderation. Prefer to store specific type of data on its corresponding field (e.g. number on a NumberField), if necessary with visible=False to hide if from the user. Also, prevent storing very large amounts of data if not necessary, as this might make your application slow and unstable!
The input can be obtained through the params argument and can have the following values:
  • json: when data is stored
  • None: when empty
    json_data = vkt.HiddenField('', name="h")  # obtained using params.h
