Options & selections
OptionField - single option
To present a dropdown list with options to select from, an OptionField can be used.
fruits = ['Avocado', 'Banana', 'Coconut']
option = vkt.OptionField('Pick your favorite fruit', options=fruits)
radio_v = vkt.OptionField('Pick your favorite fruit', options=fruits, variant='radio')
radio_h = vkt.OptionField('Pick your favorite fruit', options=fruits, variant='radio-inline')
int/float/str: when user selects an optionNone: when empty
In alphabetical order:
autoselect_single_option: (default=False) automatically select when only a single option is available, relevant in case of dynamic options
option = vkt.OptionField('Pick your favorite fruit', options=fruits, autoselect_single_option=True) -
default: a default value will be prefilled
option = vkt.OptionField('Pick your favorite fruit', options=fruits, default="Coconut") -
option = vkt.OptionField('Pick your favorite fruit', options=fruits, description="This input represents the ...") -
flex: the width of the field between 0 and 100 (default=33)
option = vkt.OptionField('Pick your favorite fruit', options=fruits, flex=50) -
name: defines the position of the parameter in the params
option = vkt.OptionField('Pick your favorite fruit', options=fruits, name="o") # obtained using params.o -
options: available options a user can select from
can be defined as list of strings
option = vkt.OptionField('Pick your favorite fruit', options=['Avocado', 'Banana', 'Coconut'])..or as list of numbers
option = vkt.OptionField('...', options=[1, 2, 3])..or as list of
OptionListElementobjectsoption = vkt.OptionField(
options=[
OptionListElement(value=1, label="Avocado"), # when selected, params.option will be 1
OptionListElement(value=2, label="Banana"),
OptionListElement(value=3, label="Coconut"),
prefix: a prefix will be put in front of the ui name
option = vkt.OptionField('Pick your favorite fruit', options=fruits, prefix="..") -
suffix: a suffix will be placed behind the ui name
option = vkt.OptionField('Pick your favorite fruit', options=fruits, suffix="..") -
variant: the field can be shown as radio buttons
option = vkt.OptionField('Pick your favorite fruit', options=fruits, variant='radio')option = vkt.OptionField('Pick your favorite fruit', options=fruits, variant='radio-inline')noteThe variants are ignored within a
Table -
option = vkt.OptionField('Pick your favorite fruit', options=fruits, visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
Autocomplete
If there are many options, it might be desirable for the user to filter options by typing. This is possible using the
AutocompleteField.
option = vkt.AutocompleteField('Pick your favorite fruit (type to filter)', options=fruits)
'Pick your favorite fruit (type to filter)', options=fruits, default="Coconut"
'Pick your favorite fruit (type to filter)', options=fruits, description="This input represents the ..."
'Pick your favorite fruit (type to filter)', options=fruits, flex=50
'Pick your favorite fruit (type to filter)', options=fruits, name="o"
'Pick your favorite fruit (type to filter)', options=['Avocado', 'Banana', 'Coconut']
option = vkt.AutocompleteField('...', options=[1, 2, 3])..or as list of
OptionListElementobjectsoption = vkt.AutocompleteField(
options=[
'Pick your favorite fruit (type to filter)', options=fruits, prefix=".."
'Pick your favorite fruit (type to filter)', options=fruits, suffix=".."
'Pick your favorite fruit (type to filter)', options=fruits, visible=vkt.Lookup("another_field")
Selecting an entity
In case you need to create an option field with entities as options, you can make use of dedicated entity selection fields.
MultiSelectField - multiple options
If multiple options need to be selectable, a MultiSelectField can be used.
options = vkt.MultiSelectField('Pick your favorite fruit(s)', options=fruits)
list: when user selects one or multiple options- empty list when nothing is selected
'Pick your favorite fruit(s)', options=fruits, default=["Avocado", "Coconut"]
'Pick your favorite fruit(s)', options=fruits, description="This input represents the ..."
'Pick your favorite fruit(s)', options=fruits, flex=50
'Pick your favorite fruit(s)', options=fruits, name="o"
'Pick your favorite fruit(s)', options=['Avocado', 'Banana', 'Coconut']
options = vkt.MultiSelectField('...', options=[1, 2, 3])..or as list of
OptionListElementobjectsoptions = vkt.MultiSelectField(
options=[
OptionListElement(value=1, label="Avocado"), # when selected, params.options will be [1]
'Pick your favorite fruit(s)', options=fruits, prefix=".."
'Pick your favorite fruit(s)', options=fruits, suffix=".."
'Pick your favorite fruit(s)', options=fruits, visible=vkt.Lookup("another_field")
Selecting entities
Dynamic options
Sometimes it is desired to create options dynamically (depending on other parameters). This can be achieved in several ways:
- Dynamically setting options using a callback function
- Setting the visibility of the
OptionListElement
Using a function
The most generic way to dynamically set the options is to use a 'callback function'. Upon evaluation of the options,
the platform passes the params, entity_id, entity_name, and workspace_id (>= v14.7.1) to the custom function.
For example, material options can be set based on a pre-selected material type as follows:
def get_material_options(params, **kwargs):
if params.material_group == 'Aluminium':
return ['Aluminium 5083', 'Aluminium 6082']
elif params.material_group == 'Steel':
return ['Steel S355', 'Steel S690']
else:
return []
material_group = vkt.OptionField('Material group', options=['Aluminium', 'Steel'])
material_type = vkt.OptionField('Material', options=get_material_options)
All individual kwargs can be added explicitly in the signature if needed:
def get_material_options(params, entity_id, entity_name, workspace_id, **kwargs):
With a callback function it is also possible to make use of the entity_id to navigate to and obtain data from other
entities using the API.
OptionListElement visibility
The same dynamic options as above can be achieved by making use of the visible argument on an OptionListElement. By
using the IsEqual and Lookup operators, we can make use of the visibility to hide/show options, similar as
hiding/showing fields:
material_options = [
vkt.OptionListElement('Aluminium 5083', visible=vkt.IsEqual(vkt.Lookup('material_group'), 'Aluminium')),
vkt.OptionListElement('Aluminium 6082', visible=vkt.IsEqual(vkt.Lookup('material_group'), 'Aluminium')),
vkt.OptionListElement('Steel S355', visible=vkt.IsEqual(vkt.Lookup('material_group'), 'Steel')),
vkt.OptionListElement('Steel S690', visible=vkt.IsEqual(vkt.Lookup('material_group'), 'Steel'))
material_type = vkt.OptionField('Material', options=material_options)
Inside a DynamicArray
If the options should be filled depending on another field within a DynamicArray, a callback function can be used to return a list of lists. Each sublist represents the options of the corresponding array row. Make sure that the length of the list is equal to the number of rows in the array:
options = []
for row in params.array:
if row['material_group'] == 'Aluminium':
options.append(['Aluminium 5083', 'Aluminium 6082'])
elif row['material_group'] == 'Steel':
options.append(['Steel S355', 'Steel S690'])
return options
array = vkt.DynamicArray('Array')
array.material_group = vkt.OptionField('Material group', options=['Aluminium', 'Steel'])
array.material_type = vkt.OptionField('Material', options=get_material_options)
