Map features
The geo-fields, enable the user to define geo-objects on a
MapView / GeoJSONView.
GeoPointField - draw a point
The GeoPointField enables the user to draw a point on the map. It should be used in combination with a MapView or GeoJSONView.
geo_point = vkt.GeoPointField('Draw a point')
GeoPointobject: when a point is drawn (see link geo-fields to a view for an example of usage)None: when empty
In alphabetical order:
default: a default value will be prefilled
geo_point = vkt.GeoPointField('Draw a point', default=vkt.GeoPoint(lat=51.9225, lon=4.4719)) -
geo_point = vkt.GeoPointField('Draw a point', description="This field represents the ...") -
name: defines the position of the parameter in the params
geo_point = vkt.GeoPointField('Draw a point', name="g") # obtained using params.g -
geo_point = vkt.GeoPointField('Draw a point', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
GeoPolylineField - draw a (poly)line
The GeoPolylineField enables the user to draw a polyline on the map. It should be used in combination with a MapView or GeoJSONView.
geo_polyline = vkt.GeoPolylineField('Draw a polyline')
GeoPolylineobject: when a point is drawn (see link geo-fields to a view for an example of usage)None: when empty
'Draw a polyline',
default=vkt.GeoPolyline(
vkt.GeoPoint(lat=51.9225, lon=4.4719),
vkt.GeoPoint(lat=52.3600, lon=4.8853),
geo_polyline = vkt.GeoPolylineField('Draw a polyline', description="This field represents the ...") -
geo_polyline = vkt.GeoPolylineField('Draw a polyline', name="g") # obtained using params.g -
geo_polyline = vkt.GeoPolylineField('Draw a polyline', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
GeoPolygonField - draw a polygon
The GeoPolygonField enables the user to draw a polygon on the map. It should be used in combination with a MapView or GeoJSONView.
geo_polygon = vkt.GeoPolygonField('Draw a polygon')
GeoPolygonobject: when a point is drawn (see link geo-fields to a view for an example of usage)None: when empty
'Draw a polygon',
default=default=vkt.GeoPolygon(
vkt.GeoPoint(lat=52.0908, lon=5.1216),
geo_polygon = vkt.GeoPolygonField('Draw a polygon', description="This field represents the ...") -
geo_polygon = vkt.GeoPolygonField('Draw a polygon', name="g") # obtained using params.g -
geo_polygon = vkt.GeoPolygonField('Draw a polygon', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
Visualize geo-objects on the map
The above geo-fields let the user 'draw' geo-objects, but does not actually visualize it on the map. If visualizing the geo-objects on the map is desired, this can easily be achieved by making use of the class-method on the corresponding map feature as described here.
Interact with geo-objects on the map
In addition to visualizing geo-objects, it is also possible to let the user interact with the geo-objects on the map.
