LLM Chat
New in v14.21.0
BETA
This feature is currently in BETA, which means:
  • We reserve the right to make breaking changes without prior notice.
  • You might lose the chat's history when resetting to an old entity revision. If this happens, you can solve the associated error by clearing the chat's history.
A Chat enables the user to have a conversation with an LLM from within the app editor.
chat = vkt.Chat("Chatbot", method="call_llm")
def call_llm(self, params, **kwargs):
conversation = params.chat
messages = conversation.get_messages()
... # here code is added to call the LLM
return vkt.ChatResult(...)
The Controller accesses user messages by calling the get_messages method on the ChatConversation object obtained from params.chat
get_messages can be used to get the full history of the conversation, which returns a list of messages with format, where 'role' indicates who sent the message (user or assistant):
'role': str, # user | assistant
'content': str, # the actual message
The current state of the conversation is sent to the LLM and retrieves its response, which is returned from the Chat method within a ChatResult.
Before the controller can pass the retrieved conversation history to any LLM client, the application must have access to a valid API key. The following section will explain how this is done for the different providers
API key configuration
Integrating a Large Language Model (LLM) into a VIKTOR application requires an API key from the chosen LLM provider. This key must be securely stored and made accessible to the application using environment variables.
Obtaining an API key
API keys are obtained directly from the respective LLM provider. The table below provides links to pages where you can find or generate your key toeg:
ProviderAPI key linkSafety
OpenAI (GPT)API keysSafety tips
Anthropic (Claude)API keysKey safety
Google (Gemini)API keysSecurity
Setting API keys as environment variables
You can set environment variables directly when running VIKTOR CLI commands using the --env or -e flag when running the install, start and run commands.
For example, to start your app with a specific OpenAI API key:
viktor-cli start --env OPENAI_API_KEY="your-api-key"
Replace "your-api-key" with the actual API key you want to use for this session. The CLI will connect the local app code to your VIKTOR environment as usual, but with the addition that the environment variable has been set on the running Python process.
Accessing API keys in application code:
Environment variables can be accessed within app.py or other relevant Python modules using the built-in os module in combination with the os.getenv() function.
# app.py
import os
# Example: Accessing OpenAI API Key
OPENAI_API_KEY = os.getenv("OPENAI_API_KEY")
# OPENAI_API_KEY is now available for use with LLM clients if set in the environment
Calling the LLM from the controller
With the correct API key set up, we can connect the app with the actual LLM.
A multi-turn chat workflow can be implemented for each of the main LLM providers as shown below. Each provider requires the installation of its corresponding Python client and may need specific handling of the chat history to meet its role formatting requirements (e.g., user, assistant).
New in v14.29.0
The Viktor LLM service uses an OpenAI-compatible API — no external API key or third-party account is required. Add the openai Python library to your requirements.txt and reinstall before using this client.
from openai import OpenAI # don't forget to add in requirements.txt and re-install
client = OpenAI(
base_url=vkt.ViktorOpenAI.get_base_url(version="v1"),
api_key=vkt.ViktorOpenAI.get_api_key(),
chat = vkt.Chat("Chat", method="call_llm")
if not conversation:
return None
vkt_messages = conversation.get_messages()
messages = [
"role": "system",
"content": "You are a helpful assistant that responds with simple but formal British English.",
messages.extend(vkt_messages)
completion = client.chat.completions.create(
model="openai.gpt-oss-120b",
messages=messages,
return vkt.ChatResult(conversation, completion.choices[0].message.content)
Remark
When using Viktor LLM's chat completion API, prepend a system message to the history manually, as VIKTOR's ChatConversation does not include the system role by default.
For streaming responses, the LLM client yields parts of the response as they are generated, rather than waiting for the complete response. This can improve perceived performance for the user. The ChatResult can accept an iterable of strings for streaming.
client = OpenAI(
return None
messages = [
"role": "system",
stream = client.chat.completions.create(
messages=messages,
stream=True,
text_stream = (
chunk.choices[0].delta.content
for chunk in stream
if chunk.choices[0].delta.content is not None
return vkt.ChatResult(conversation, text_stream)
For more details on the Viktor LLM service — including the Responses API with tool use — see the Viktor LLM section.
Publishing an app
For published applications, API keys can be set, updated, or removed from the 'Apps' section in your VIKTOR environment. Once configured, these environment variables are securely stored and available in the application’s code during runtime. This replaces the use of .env files or passing keys through the VIKTOR CLI for deployed apps.
Detailed guidance is available in the VIKTOR environment variables documentation.
More info
The technical API reference, can be found here: Chat
In alphabetical order:
  • first_message (optional): the first message that will appear on top of the empty conversation
    chat = vkt.Chat(..., first_message="How can I help you?")
  • flex (optional): the width of the field between 0 and 100 (default=33)
    chat = vkt.Chat(..., flex=50)
  • method (required): the controller method that will be triggered when the user clicks the "send" button
    chat = vkt.Chat(..., method='call_llm')
  • placeholder (optional): placeholder message in the user prompt
    chat = vkt.Chat(..., placeholder="Ask anything")
  • visible (optional): can be used when the visibility depends on other input fields
    chat = vkt.Chat(..., visible=vkt.Lookup("another_field"))
    See 'Hide a field' for elaborate examples.
Limitations
The VIKTOR SDK currently supports only the 'user' and 'assistant' roles for messages within the ChatConversation. For other roles (e.g., 'system', 'tool'), additional processing may be required depending on the specific LLM client being used.
The maximum response size in the ChatResult is 75000 characters.
