Geometry selection
New in v14.10.0
The geometry selection fields, enable the user to select geometries in an IFCView or a GeometryView.
Reference
GeometrySelectField - select a geometry​
The GeometrySelectField enables the user to select a single (sub-)geometry in a geometric view. It should be used in combination with an IFCView or GeometryView (showing TransformableObject or .3dm files).
geometry = vkt.GeometrySelectField("Select Geometry")
  • string: when a geometry is selected
  • None: when empty
In alphabetical order:
  • default: a default value will be prefilled
    geometry = vkt.GeometrySelectField("Select Geometry", default="cube1")
  • description: add a tooltip with additional information
    geometry = vkt.GeometrySelectField("Select Geometry", description="This field represents the ...")
  • flex: the width of the field between 0 and 100 (default=33)
    geometry = vkt.GeometrySelectField("Select Geometry", flex=50)
  • name: defines the position of the parameter in the params
    geometry = vkt.GeometrySelectField("Select Geometry", name="g")  # obtained using params.g
  • view: view method to which the field is connected (default: first GeometryView / IFCView)
    geometry = vkt.GeometrySelectField("Select Geometry", view="geometry_view")
  • visible: can be used when the visibility depends on other input fields
    geometry = vkt.GeometrySelectField("Select Geometry", visible=vkt.Lookup("another_field"))
    See 'Hide a field' for elaborate examples.
Select multiple geometries​
The GeometryMultiSelectField enables the user to select multiple (sub-)geometries in a geometric view. It should be used in combination with an IFCView or GeometryView.
geometries = vkt.GeometryMultiSelectField("Select Geometries")
  • list of string: when geometries are selected
  • empty list when empty
    geometries = vkt.GeometryMultiSelectField("Select Geometries", default=["cube1", "cube3"])
    geometries = vkt.GeometryMultiSelectField("Select Geometries", description="This field represents the ...")
    geometries = vkt.GeometryMultiSelectField("Select Geometries", flex=50)
  • max_select: maximum amount of objects the user is allowed to select
    geometry = vkt.GeometryMultiSelectField("Select Geometries", max_select=5)
  • min_select: minimum amount of objects the user needs to select
    geometry = vkt.GeometryMultiSelectField("Select Geometries", min_select=3)
    geometries = vkt.GeometryMultiSelectField("Select Geometries", name="g")  # obtained using params.g
    geometries = vkt.GeometryMultiSelectField("Select Geometries", view="geometry_view")
    geometries = vkt.GeometryMultiSelectField("Select Geometries", visible=vkt.Lookup("another_field"))
Example​
To support geometry selection, the following parts need to be implemented in the app:
  1. Create an IFCView in the controller
  2. Create a FileField and GeometrySelectField (or GeometryMultiSelectField) in the parametrization
  3. Use the identifier retrieved from the params in subsequent calculations
An IFC-file contains unique identifiers per geometry feature.
import ifcopenshell
import ifcopenshell.util.element
from tempfile import NamedTemporaryFile
ifc = vkt.FileField("Please provide an IFC file")
@vkt.IFCAndDataView("IFC", x_axis_to_right=True)
def get_ifc_and_data_view(self, params, **kwargs):
ifc_file = params.ifc.file
if selected_geometry := params.geometry: # If user has made a selection, add its properties to `data`
# parse your ifc file (e.g. with ifcopenshell as below)
with NamedTemporaryFile(suffix=".ifc", delete=False, mode="w") as temp_f:
temp_f.write(ifc_file.getvalue())
model = ifcopenshell.open(Path(temp_f.name))
elem = model.by_id(int(selected_geometry))
# See https://wiki.osarch.org/index.php?title=IFC_attributes_and_properties
# for a list of available IFC attributes and properties
data_items = []
for key, val in ifcopenshell.util.element.get_psets(elem).items():
sub_data_items = []
for k,v in val.items():
sub_data_items.append(vkt.DataItem(k, v))
data_items.append(vkt.DataItem(key, '', subgroup=vkt.DataGroup(*sub_data_items)))
data = vkt.DataGroup(*data_items)
else:
data = vkt.DataGroup(vkt.DataItem('No geometries selected', ''))
return vkt.IFCAndDataResult(ifc=ifc_file, data=data)
