Entity selection
When an entity depends on data of one or more other entities, the entity selection fields enable the user to make this selection. This is especially useful when making a tree-type app.
If none of the below entity selection fields are sufficient, data between entities can be shared using the API.
ChildEntityOptionField - select child(ren)
For the selection of a single child entity, the ChildEntityOptionField can be used. For example, when the entity
type structure of your application looks similar to the following, and you need your users to select one of the child
entities of a Parent, the following code can be used:
Parent
└── Child
entity = vkt.ChildEntityOptionField('Select a child entity')
Entityobject: when user selects an entityNone: when empty
In alphabetical order:
entity = vkt.ChildEntityOptionField('Select a child entity', description="This field represents the ...") -
entity_type_names: users will only be able to select entities of types within this list
entity = vkt.ChildEntityOptionField('Select a child entity', entity_type_names=["TypeA", "TypeC"]) -
flex: the width of the field between 0 and 100 (default=33)
entity = vkt.ChildEntityOptionField('Select a child entity', flex=50) -
name: defines the position of the parameter in the params
entity = vkt.ChildEntityOptionField('Select a child entity', name="e") # obtained using params.e -
entity = vkt.ChildEntityOptionField('Select a child entity', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
Select multiple children
In case multiple children should be selectable, the ChildEntityMultiSelectField can be used.
entities = vkt.ChildEntityMultiSelectField('Select child entities')
listofEntityobjects: when user selects an entity- empty list when empty
entities = vkt.ChildEntityMultiSelectField('Select child entities', description="This field represents the ...") -
entities = vkt.ChildEntityMultiSelectField('Select child entities', entity_type_names=["TypeA", "TypeC"]) -
entities = vkt.ChildEntityMultiSelectField('Select child entities', flex=50) -
entities = vkt.ChildEntityMultiSelectField('Select child entities', name="e") # obtained using params.e -
entities = vkt.ChildEntityMultiSelectField('Select child entities', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
SiblingEntityOptionField - select sibling(s)
Similar to children, siblings can be selected using the SiblingEntityOptionField. For example, when the entity
type structure of your application looks similar to the following, and you need your users to select entities of
type SiblingB from an editor in SiblingA, the following code can be used:
Parent
├── SiblingA
└── SiblingB
entity = vkt.SiblingEntityOptionField('Select a sibling')
entity = vkt.SiblingEntityOptionField('Select a sibling', description="This field represents the ...") -
entity = vkt.SiblingEntityOptionField('Select a sibling', entity_type_names=["TypeA", "TypeC"]) -
entity = vkt.SiblingEntityOptionField('Select a sibling', flex=50) -
entity = vkt.SiblingEntityOptionField('Select a sibling', name="e") # obtained using params.e -
entity = vkt.SiblingEntityOptionField('Select a sibling', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
Select multiple siblings
In case multiple siblings should be selectable, the SiblingEntityMultiSelectField can be used.
entities = vkt.SiblingEntityMultiSelectField('Select sibling entities')
entities = vkt.SiblingEntityMultiSelectField('Select sibling entities', description="This field represents the ...") -
entities = vkt.SiblingEntityMultiSelectField('Select sibling entities', entity_type_names=["TypeA", "TypeC"]) -
entities = vkt.SiblingEntityMultiSelectField('Select sibling entities', flex=50) -
entities = vkt.SiblingEntityMultiSelectField('Select sibling entities', name="e") # obtained using params.e -
entities = vkt.SiblingEntityMultiSelectField('Select sibling entities', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
EntityOptionField - select any entity
In some cases, both the ChildEntityOptionField and SiblingEntityOptionField may not be sufficient because the
entities you need to select are in a different part of the entity type tree. In the following example, we want to
select a CPTFile entity in a Foundation entity:
ProjectFolder
└── Project
├── CPTFolder
│ └── CPTFile
└── Foundation
We can make use of the EntityOptionField and the entity_type_names attribute to filter which entity type(s) should
be selectable:
selected_cpt = vkt.EntityOptionField('CPT File', entity_type_names=['CPTFile'])
entity = vkt.EntityOptionField('CPT File', description="This field represents the ...") -
entity = vkt.EntityOptionField('CPT File', entity_type_names=["TypeA", "TypeC"]) -
entity = vkt.EntityOptionField('CPT File', flex=50) -
entity = vkt.EntityOptionField('CPT File', name="e") # obtained using params.e -
entity = vkt.EntityOptionField('CPT File', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
Select multiple entities
Multiple entities can be selected by using EntityMultiSelectField.
selected_cpt = vkt.EntityMultiSelectField('CPT File(s)', entity_type_names=['CPTFile'])
entities = vkt.EntityMultiSelectField('CPT File(s)', description="This field represents the ...") -
entities = vkt.EntityMultiSelectField('CPT File(s)', entity_type_names=["TypeA", "TypeC"]) -
entities = vkt.EntityMultiSelectField('CPT File(s)', flex=50) -
entities = vkt.EntityMultiSelectField('CPT File(s)', name="e") # obtained using params.e -
entities = vkt.EntityMultiSelectField('CPT File(s)', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
Entity object
When the user selects an entity with these fields, the entity is returned in the params as Entity object. For more
detail on how to use an Entity, see this guide.
cpt_entity = vkt.EntityOptionField('Select a CPT', entity_type_names=['CPTFile'])
@vkt.DataView("CPT data")
def visualize(self, params, **kwargs):
cpt_entity = params.cpt_entity # Entity | None
if cpt_entity:
return vkt.DataResult(vkt.DataGroup(
x=vkt.DataItem('CPT X coordinate', cpt_entity.last_saved_params.x_coordinate),
y=vkt.DataItem('CPT Y coordinate', cpt_entity.last_saved_params.y_coordinate)
return vkt.DataResult(vkt.DataGroup())
