Spreadsheet templater
caution
Services need to be mocked within the context of (automated) testing.
This guide will assume the template (represented by bytes) is available. Either named cells (cells which can be found
using a certain key) or direct cells (cell which can be found by a direct address {sheet, column, row}) can be used to
fill the template.
An example implementation of how a spreadsheet template can be filled can be found below.
cells = [
vkt.spreadsheet.DirectInputCell('sheet1', 'A', 1, 5),
vkt.spreadsheet.NamedInputCell('named_cell_1', 'text_to_be_placed'),
template_path = Path(__file__).parent / 'my' / 'relative' / 'path' / 'template.xlsx'
with open(template_path, 'rb') as template:
filled_spreadsheet = vkt.spreadsheet.render_spreadsheet(template, cells)
When large blocks of cells need to be filled, an
InputCellRange can be used.
