Converting to PDF
caution
Services need to be mocked within the context of (automated) testing.
Various formats can be converted to PDF using VIKTOR's built-in services. Converters for the following file types are currently supported:
Word to PDF​
A Word file can be converted to PDF using the convert_word_to_pdf function:
# using File object
file1 = vkt.File.from_path(Path(__file__).parent / "mydocument.docx")
with file1.open_binary() as f1:
pdf = vkt.convert_word_to_pdf(f1)
# using built-in `open()`
with open(Path(__file__).parent / "mydocument.docx", "rb") as f1:
Excel to PDF​
An Excel file can be converted to PDF using the convert_excel_to_pdf function:
# using File object
file1 = vkt.File.from_path(Path(__file__).parent / "mydocument.xlsx")
pdf = vkt.convert_excel_to_pdf(f1)
with open(Path(__file__).parent / "mydocument.xlsx", "rb") as f1:
SVG to PDF​
An SVG image file can be converted to PDF using the convert_svg_to_pdf function:
# using File object
file1 = vkt.File.from_path(Path(__file__).parent / "mydocument.svg")
pdf = vkt.convert_svg_to_pdf(f1)
with open(Path(__file__).parent / "mydocument.svg", "rb") as f1:
