App types
The type of app can be set in the viktor.config.toml file by
means of the app_type
entry. App layout, requirements and corresponding feedback errors might differ depending on the
chosen app type. Currently, the following types are available:
Editor: the app consists of a single editor. Every users gets a 'fresh' editor upon entry and data is not saved.
Tutorial
Simple: the app consists of a single entity type. Users can create, save and edit instances of this type. Entities are shared among multiple users.
Tutorial
Tree: the app consists of multiple entity types in a developer-specified hierarchy. Entities are shared among multiple users.
Tutorial
Editor-type app
The simplest app structure consists of a single editor only. The user automatically enters the editor when opening the application workspace, with no additional navigation functionalities.
When a user opens the workspace, a unique session is created. Sessions are not shared among multiple users, and are automatically closed when leaving the editor (state is not saved).
The following are not available for the 'editor' app type:
Simple-type app
The simple
is similar to the editor
type, however the user is able to create multiple entities of an entity type and
the state of an entity can be saved. Earlier created revisions can be restored if desired. The user enters a folder and can navigate to the desired entity by selecting from the entity table.
Tree-type app
More complex apps, consisting of an entity type hierarchy, can be created by choosing the tree
app type.
Recommended folder structure
The app.py
file can quickly become cluttered with a lot of code if your app grows in size. For tree-type apps we
recommend to separate the code in sub-folders. This can be done by replacing the app.py
file with a file called
__init__.py
within a folder named app
and add sub-folders per entity type. Furthermore, it might be desirable to
also split the controller and parametrization classes into separate files. For a hypothetical app with entity types
BlueType
and GreenType
this looks as follows:
my-folder
├── app
│ ├── blue_type
│ │ ├── __init__.py
│ │ ├── controller.py
│ │ └── parametrization.py
│ ├── green_type
│ │ ├── __init__.py
│ └── __init__.py <- this is the new entry point of your app, replacing app.py
The __init__.py
files in the entity type sub-folders are required to make Python treat directories containing the
file as packages and can be left empty.
Importing controllers
If the controller class is in a separate file, it can be imported in the app's __init__.py
file using Python's
import
command. For example, a controller class named BlueType
in a file blue_type/controller.py
can be imported
in __init__.py
as follows:
from .blue_type.controller import BlueType # defines entity type 'BlueType'
If the class name itself does not equal the entity type name, you can import as an alias. For example, a class named
Controller
file to act as the
controller for the BlueType
entity type as follows:
from .blue_type.controller import Controller as BlueType # defines entity type 'BlueType'
Initial entities
For a tree
app type, it's required to define intial entities in code, since the top layer is not editable by the user. See this page for more information.
