Creating a simple-type app
In this tutorial we will create a simple-type application; an app that consists of only one single entity type.
The main difference with the editor-type app is that with the simple-type app you can create as many objects (entities) as you want. Each object editor stores its own (unique) data.
The app visualizes world population and life expectancy data in a few different ways:
  1. bar chart of the Netherlands
  2. animated scatter plot per continent
  3. world map surface plot
The end result can be downloaded here.
For more examples of applications, please visit the sample apps
Creating an empty app
A template 'simple' type app can be generated using the CLI. We will use this template app as a starting point for the tutorial. Run the following command (replace simple-tutorial with the folder name of your choice):
viktor-cli create-app --app-type simple simple-tutorial
Folder structure
simple-tutorial
├── app.py
├── CHANGELOG.md
├── README.md
├── tests
│ └── __init__.py
Note that the app type ('simple') has been defined in viktor.config.toml:
Dependencies
Navigate to the newly created folder and open requirements.txt and add plotly as additional requirement. We will use this package to create the (interactive) visualizations.
viktor==X.X.X
plotly
Installation
Now run the install command from within the folder to install the app and its dependencies, clear any previous saved local database, and run start to start to app:
viktor-cli install
viktor-cli clear
Login to the app in your browser to verify that the app is installed and running as expected. You will be redirected to the app's editor, which is currently a blank page.
If you see the "Workspaces" menu upon logging in, click the "Open" button on the "Development" workspace. After opening, you will be redirected to the app's editor.
Defining the editor (input / output)
Open app.py and replace it with the following code:
from viktor import ViktorController
from viktor.parametrization import ViktorParametrization, OptionField
from viktor.views import PlotlyView, PlotlyResult
import plotly.express as px
_options = ["The Netherlands", "Continents", "Global"]
graph = OptionField("Life expectancy:", options=_options, default="Continents", variant="radio", flex=100)
label = 'My Entity Type'
parametrization = Parametrization(width=20)
@PlotlyView("Life Expectancy", duration_guess=3)
def plotly_view(self, params, **kwargs):
dataframe = px.data.gapminder()
if params.graph == 'The Netherlands':
data = dataframe.query("country == 'Netherlands' ")
fig = px.bar(data, x='year', y='pop', color='lifeExp')
elif params.graph == 'Continents':
fig = px.scatter(dataframe, x="gdpPercap", y="lifeExp", animation_frame="year", animation_group="country",
size="pop", color="continent", hover_name="country", facet_col="continent",
log_x=True, size_max=75, range_x=[100, 100000], range_y=[25, 90])
elif params.graph == 'Global':
fig = px.choropleth(dataframe, locations='iso_alpha', color='lifeExp', hover_name='country',
animation_frame='year', color_continuous_scale=px.colors.sequential.Plasma,
projection='natural earth')
else:
raise NotImplementedError
return PlotlyResult(fig.to_json())
In your browser, click on "+ Create", as shown in the image below.
Fill in a name in the pop-up, and click “Create and open”, to create the object (entity) and open its editor.
On the left side, you will now see radio buttons with the defined options. Go ahead and select another option and see how it influences the results on the right-hand side. Save your changes by clicking the disk icon in the top-right corner of the screen (encircled in red in the image below).
