Numeric input
NumberField - decimal numbers
A NumberField is a generic numeric field that can contain numbers with decimals. It can be visualized as
numerical input or slider variant:
number = vkt.NumberField('Insert a Number here')
slider = vkt.NumberField('Adjust the Number', min=0, max=8, variant='slider')
float: when user inputs a decimal number (e.g. 1.5)int: when user inputs a whole number (e.g. 1)None: when empty (not applicable to the slider variant)
In alphabetical order:
default: a default value will be prefilled
number = vkt.NumberField('Insert a Number here', default=7.5) -
number = vkt.NumberField('Insert a Number here', description="This number represents the ...") -
flex: the width of the field between 0 and 100 (default=33)
number = vkt.NumberField('Insert a Number here', flex=50) -
max: when the user enters a value higher than the maximum boundary, the field is marked as invalid
number = vkt.NumberField('Insert a Number here', max=10)See 'Setting min/max' for more information on setting a dynamic boundary.
min: when the user enters a value lower than the minimum boundary, the field is marked as invalid
number = vkt.NumberField('Insert a Number here', min=0)See 'Setting min/max' for more information on setting a dynamic boundary.
name: defines the position of the parameter in the params
number = vkt.NumberField('Insert a Number here', name="n") # obtained using params.n -
num_decimals: defines the number of decimals shown in the interface
number = vkt.NumberField('Insert a Number here', num_decimals=2) -
prefix: a prefix will be put in front of the ui name
number = vkt.NumberField('Insert a Number here', prefix="€") -
step: stepping interval when clicking the increment / decrement buttons
number = vkt.NumberField('Insert a Number here', step=0.5) -
suffix: a suffix will be placed behind the ui name
number = vkt.NumberField('Insert a Number here', suffix="mm") -
variant: the field can be shown as slider, in this case specifying a
minandmaxis requirednumber = vkt.NumberField('Adjust the Number', min=0, max=8, variant='slider')noteThe variants are ignored within a
Table -
number = vkt.NumberField('Insert a Number here', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
IntegerField - whole numbers
An IntegerField is a numeric field that can contain integers only.
integer = vkt.IntegerField('Input an Integer')
int: when user inputs a number (e.g. 1)None: when empty
integer = vkt.IntegerField('Input an Integer here', default=7.5) -
integer = vkt.IntegerField('Input an Integer here', description="This number represents the ...") -
integer = vkt.IntegerField('Input an Integer here', flex=50) -
integer = vkt.IntegerField('Input an Integer here', max=10)See 'Setting min/max' for more information on setting a dynamic boundary.
integer = vkt.IntegerField('Input an Integer here', min=0)See 'Setting min/max' for more information on setting a dynamic boundary.
integer = vkt.IntegerField('Input an Integer here', name="i") # obtained using params.i -
integer = vkt.IntegerField('Input an Integer here', prefix="€") -
integer = vkt.IntegerField('Input an Integer here', step=3) -
integer = vkt.IntegerField('Input an Integer here', suffix="mm") -
integer = vkt.IntegerField('Input an Integer here', visible=vkt.Lookup("another_field"))See 'Hide a field' for elaborate examples.
Setting min/max
The min and max value of the field can be set using the min and max arguments respectively:
vkt.NumberField('X', min=0, max=10) # also on IntegerField
When the user enters a value that exceeds these bounds, the fields are marked as invalid.
If the value for min or max needs to be calculated 'dynamically', one of the below methods can be used.
Depending on another field
If the constraint depends on another numeric field, the easiest solution is to use a
Lookup:
param_x = vkt.NumberField('X')
param_y = vkt.NumberField('Y', min=vkt.Lookup('param_x'))
In case of a nested parametrization structure, the dotted path should be used:
vkt.Lookup('tab.section.param_x')
When the target field cannot be found, a warning is logged in your terminal and the constraint is ignored.
Inside a DynamicArray
If the value for min or max depends on the result of another numeric field within a DynamicArray, a
RowLookup can be used. Using the RowLookup, a field of a specific row within the array can be made
dependent of another field within the same row:
array = vkt.DynamicArray('Array')
array.param_x = vkt.NumberField('X')
array.param_y = vkt.NumberField('Y', min=vkt.RowLookup('param_x'))
Using a function
The most generic way to dynamically set the min/max value is to use a callback function. Upon evaluation of the min
or max constraint, the platform passes the params, entity_id, entity_name, and workspace_id (>= v14.7.1) to the
custom function:
def param_y_min(params, **kwargs):
return params.param_x
param_y = vkt.NumberField('Y', min=param_y_min)
For constraints that have to be applied to fields within a DynamicArray, make sure that the callback function returns
a list of the constraint values, one for each row in the array. The length of this list must be equal to the number of
rows in the array, otherwise (a warning is logged and) the constraint is ignored:
return [row.param_x for row in params.array]
array.param_y = vkt.NumberField('Y', min=param_y_min)
All individual kwargs can be added explicitly in the signature if needed:
def param_y_min(params, entity_id, entity_name, workspace_id, **kwargs):
When the value for min/max depends on data from another entity, the entity_id can be used to navigate and obtain data
using the SDK API.
