Static image
A static image (JPEG / PNG) can be displayed in the parametrization of an editor to, for example, provide additional context to help users fill in certain input fields.
Minimal implementation
Assume a folder structure as shown below:
my-folder
├── app.py
├── assets
The image viktor.png can be displayed in the parametrization by referencing to it in the app code using an
Image field:
img = vkt.Image(path="viktor.png")
The image path is relative with respect to the assets_path which can be named arbitrarily and should be defined in
the viktor.config.toml:
assets_path = "assets"
Note that the assets directory does not support nesting of directories.
You will need to re-install your app after removing the hashtag and adding the 'assets' directory.
Image customization
You can tweak the visual by specifying one or multiple of the following attributes:
align: Alignment within the parametrization component ("left" | "center" | "right")caption: A caption which is shown underneath the imageflex: Width of the image as percentage of the total parametrization widthmax_width: A maximum width (pixels) can be set to make sure an image is not stretched beyond illegible boundaries
Show/hide an image depending on user selection
There may be cases where the user needs to be informed differently depending on a previous choice. An Image cannot
have a dynamic source, however it is possible to use its visibility to show/hide a
specific image.
