Output field
For larger sections of text in the parametrization, see Text
An OutputField can be used to display a textual or numeric value to the user
within a parametrization that cannot be modified by the user. The value must be set in the parametrization and can
be a static value or obtained dynamically.
output = vkt.OutputField('Output', value=3.1415)
The value of the OutputField field is not included in the params.
Dynamic value
Depending on another field
If the value depends on another field, the easiest solution is to use a Lookup:
param_x = vkt.NumberField('X')
output = vkt.OutputField('X (read only)', value=vkt.Lookup('param_x'))
Inside a DynamicArray
If the value depends on the result of another field within a DynamicArray,
a RowLookupcan be used. Using the RowLookup, the value of a field in a specific row can be made read-only:
array = vkt.DynamicArray('Array')
array.param_x = vkt.NumberField('X')
array.output = vkt.OutputField('X (read only)', value=vkt.RowLookup('param_x'))
Using a function
The most generic way to dynamically set the value is to use a callback function. Upon evaluation of the
value, the platform passes the params, entity_id, entity_name, and workspace_id (>= v14.7.1)
to the custom function:
def sum_x_y(params, **kwargs):
return params.param_x + params.param_y
param_y = vkt.NumberField('Y')
output = vkt.OutputField('X + Y', value=sum_x_y)
If the OutputField is defined within a DynamicArray, make sure that the callback function returns
a list of values, one for each row in the array. The length of this list must be equal to the number
of rows in the array, otherwise (a warning is logged and) the field will be empty:
return [row.param_x + row.param_y for row in params.array]
array.param_y = vkt.NumberField('Y')
array.output = vkt.OutputField('X + Y', value=sum_x_y)
All individual kwargs can be added explicitly in the signature if needed:
def sum_x_y(params, entity_id, entity_name, workspace_id, **kwargs):
When the value depends on data of another entity, the entity_id can be used to navigate and obtain data using
the SDK API.
