Changelog
All notable changes to the VIKTOR CLI will be documented in this file.
v0.50.1 - 21/09/2026
Fixed
- Escaped the Markdown-significant characters in the
publishlong description, so the generated CLI reference builds and renders correctly in the docs
v0.50.0 - 18/09/2026
Added
- Added
--yesflag on thepublishcommand to answer all confirmation prompts with yes, to publish non-interactively
Security
- Updated
golang.org/x/cryptoto v0.56.0, mitigating CVE-2026-56855 and CVE-2026-78662 - Updated
golang.org/x/cryptoto v0.55.0, mitigating CVE-2026-56854 (critical) and 13 further advisories - Updated
golang.org/x/netto v0.57.0, mitigating CVE-2026-25681, CVE-2026-27136, CVE-2026-39821, CVE-2026-46600 and 3 further advisories - Updated
golang.org/x/textto v0.41.0, mitigating CVE-2026-56852 - Updated
github.com/go-git/go-gitto v5.19.2, mitigating CVE-2026-71556 and CVE-2026-71557
v0.49.0 - 12/06/2026
Added
Changed
- Updated tree-type app boilerplate
create-appcommand now appends a random 6-character suffix to the registered and readable name when the app name already exists, instead of returning an error
Removed
quickstartcommand (usecreate-appinstead)
Deprecated
Fixed
Security
v0.48.0 - 16/04/2026
Changed
create-appcommand now creates an app on the VIKTOR platform. Local boilerplate generation is opt-in via--init.
Removed
--demoflag fromcreate-appcommandget-startedcommand (useactivateinstead)
Deprecated
quickstartcommand is deprecated in favor ofcreate-app
v0.47.0 - 06/02/2026
Added
- Support for
.viktorignorefile to exclude directories and files from publication
Changed
- Allow specifying account name as arg in
configure switch-accountcommand
v0.46.0 - 14/01/2026
Added
- Support for Python 3.14
v0.45.0 - 17/12/2025
Changed
- Removed support for Python 3.9
Deprecated
- Deprecated Python 3.10
v0.44.5 - 29/09/2025
Fixed
- Reverted raise error if there are uncommitted changes during publish due to problems
v0.44.4 - 24/09/2025
Added
- Raise error if there are uncommitted changes during publish
Security
- Updated golang.org/x/net package to mitigate CVE-2025-22872
- Updated
utlspackage to mitigateGHSA-pmc3-p9hx-jq96
v0.44.3 - 20/03/2025
Fixed
- Prevent double reload on Windows by discarding file watch events for
__pycache__directories
v0.44.2 - 19/02/2025
Changed
- Exit with proper code when error occurs during
ci-publish
v0.44.1 - 09/01/2025
Changed
- Repeat tag and registered name before confirming publish
Fixed
- Do not trigger immediate reload when starting an app
v0.44.0 - 19/12/2024
Added
- Attach digital signature to executable and installer
v0.43.4 - 13/12/2024
Fixed
- Set
UV_LINK_MODE=copyto prevent installation errors when copying files inside virtual environment
v0.43.3 - 10/12/2024
Fixed
- Empty suggested app name when validation of registered name fails
v0.43.2 - 09/12/2024
Added
- Add more information and options to 'invalid registered-name' prompt
Fixed
- Fix bug where registered-name would sometimes be treated as case-sensitive
v0.43.1 - 02/12/2024
v0.43.0 - 02/12/2024
Added
- Prompt to migrate development workspace when user maintains multiple apps
- Add validation on provided registered-name, prompt to select if invalid
Fixed
- Fix error during publish when
assets_pathpoints to an empty directory
v0.42.0 - 18/11/2024
Added
- Added
--use-pipflag on theinstallcommand to switch to 'pip' as package manager (default is 'uv')
Changed
- The
installcommand now uses 'uv' as package manager by default to improve performance
Fixed
- Fix setting incorrect UID / GID when running docker isolation on Windows
v0.41.5 - 11/11/2024
Fixed
- Fix quickstart command from unnecessarily prompting for
registered-name
v0.41.4 - 06/11/2024
Added
- Added
--registered-nameflag on theclearcommand
Changed
- Don't Prompt IDE when no IDEs are found on the machine of the user
v0.41.3 - 04/11/2024
Fixed
- Update false positive in
check-systemto properly handle new error format
v0.41.2 - 29/10/2024
v0.41.1 - 24/10/2024
Changed
- When running the
start,quickstart, orclean-startcommands the cli automatically updates to the latest version
v0.41.0 - 24/10/2024
Added
- Support environment variable
VIKTOR_JS_SDK_PATHused for WebView interaction - When running the
startcommand the user is prompted to upgrade if a new cli version is available - Warn when starting an app that has no
registered_namedefined - Added
--registered-nameflag on thestartcommand
Changed
- Removed environment variable
VIKTOR_SUBDOMAINwhich was incorrect and therefore has no use
Fixed
- Set ownership to HOME directory (docker isolation mode) to fix warnings regarding writing to cache (e.g. matplotlib, fontconfig etc.)
v0.40.0 - 09/10/2024
Added
- Added marker for active account for account selection prompt
- Support for Python 3.13
Changed
- Automatically detect changes to
assets_pathwhen developing
v0.39.0 - 05/09/2024
Added
- Added
hello-viktorapp toquickstartcommand - Added
activatecommand - Added resources to the output table of the
appscommand
Changed
- Updated the embedded app templates to use a single viktor import
- Updated style of the output table of the
appscommand
v0.38.0 - 12/08/2024
- Support blank apps in
quickstartcommand
v0.37.0 - 29/07/2024
Added
- Support Excel converter in
quickstartcommand
v0.36.2 - 24/07/2024
Fixed
- Disable CGO
v0.36.1 - 24/07/2024
Changed
- Updated golang to v1.22 and the dependencies to the latest versions
Fixed
- Remove venv when Python version check cannot be completed
v0.36.0 - 25/06/2024
Added
- Added
quickstartcommand to start developing from a sample app
Fixed
- Ignore nested
__pycache__directories when gathering app files for publishing
v0.35.0 - 29/04/2024
Changed
- Make
--tagflag optional inpublishcommand - Read
registered_namefrom viktor.config.toml and make--registered-nameflag optional inpublishcommand
Fixed
- Fix URL to documentation in demo app
v0.34.1 - 09/04/2024
Changed
- Removed installation of demo app from
get-startedcommand - When using
create-appin GitHub Codespaces, the codespace Python version is set in viktor.config.toml - When using
publishin GitHub Codespaces, the--use-filesystemflag will always be true - Ignore
v0.34.0 - 03/04/2024
Added
- Added
clean-startcommand which combinesclear+install+start - Support tag on
ci-publishcommand
Changed
- Maximum length of publish tag increased from 20 to 128 characters
v0.33.5 - 11/03/2024
Added
VIKTOR_CREDENTIALSused for cloud-based development (e.g. GitHub Codespaces)
Changed
- Command
upgradelogs new version when successfully upgraded - Set
x_axis_to_right=TrueonGeometryViewin demo - Command
check-systemnow also verifies credentials - Removed neverssl check in
check-systemcommand
v0.33.4 - 16/02/2024
Changed
- Improved internal error logging when freezing of virtual environment fails
v0.33.3 - 12/02/2024
Changed
- Command
installnow uninstalls previous installation instead of removing the entire venv directory to resolve vscode intellisense (Pylance) issues - Omit the
<NAME>argument in thecreate-appcommand to create a new app in the current directory
v0.33.2 - 02/02/2024
Changed
- Per user installation of CLI to no longer require administrator privileges
v0.33.1 - 11/01/2024
Changed
- Set default Python version of demo app to 3.12
Fixed
- Unpin numpy in demo app to fix compatibility with Python 3.12
v0.33.0 - 08/01/2024
Added
- Support for Python 3.12
- Show message to user if token has been deactivated
Deprecated
- Deprecated Python 3.8
v0.32.0 - 24/11/2023
Added
- Support 'packages' in viktor.config.toml
v0.31.2 - 01/11/2023
Changed
- Add a flag to use pip truststore, this allows users to disable installation with truststore
v0.31.1 - 31/10/2023
Changed
- Removed neverssl check from newAPI function
v0.31.0 - 24/10/2023
Changed
- When available use
truststorefeature of pip to prevent SSL installation errors
v0.30.7 - 23/10/2023
Fixed
- Warning for Python version was always triggered instead of only for invalid Python versions
v0.30.6 - 17/10/2023
Changed
- Log warning when found Python version with Python Launcher is not supported for use with VIKTOR
v0.30.5 - 11/10/2023
Changed
- Added 'command' sentry tag on all commands
- Print files to be uploaded during publish and prompt user to continue
v0.30.4 - 19/09/2023
Changed
- Updated golang to v1.21 and the dependencies to the latest versions
v0.30.3 - 28/08/2023
Changed
- Capture actual error message when activation code cannot be obtained
v0.30.2 - 07/08/2023
Fixed
- get-started now installs demo app in temporary dir to fix potential permission errors
check-systemremoved fall-back on ping command when curl is not available since it is unable to receive
v0.30.1 - 18/07/2023
Added
- Added a prompt to overwrite configuration file entry if it is already present while rerunning the
get-startedcommand
v0.30.0 - 11/07/2023
Added
- Read 'assets_path' from viktor.config.toml and upload assets to S3
Removed
- Removed
--regionflag frompublish,ci-publish,apps,describecommands since apps are now automatically synced
v0.29.11 - 16/06/2023
- Only autoselect Python installation when running get-started, print the selected path and give hint how to change
v0.29.10 - 09/06/2023
Added
- Add max-memory flag to install and test command to prevent container crashing on large packages
Changed
check-systemcommand shouldn't fail because curl or ping is not installed, instead a nil error is returned and message is logged in Sentry
v0.29.9 - 24/05/2023
Changed
- Updated the text of the last step in demo app including utm source tag for tracking the clickthrough rate into the tutorial
v0.29.8 - 16/05/2023
Added
- Added Stdout output to error tracking in Sentry when installation of the demo app fails
Fixed
- Properly skip virtual environment and .git directories during publish
v0.29.7 - 26/04/2023
Changed
- Removed sentry error tracking when directory cannot be created or app files cannot be copied in
create-appcommand
v0.29.6 - 13/04/2023
Changed
- Select the currently active account by default instead of the default account when running configure without --name flag
Fixed
- Exclude false positive curl error from system check
v0.29.5 - 12/04/2023
Fixed
- Demo app crashes due to removed UserException in SDK v14
v0.29.4 - 12/04/2023
Changed
- Get latest SDK from PyPI instead of system
Removed
- Removed U83 flag from app templates
v0.29.3 - 17/03/2023
Fixed
- Fixed numpy in demo app not compatible with Python 3.7
v0.29.2 - 17/03/2023
Changed
- Raise error when defining viktor in requirements.txt with a leading hashtag in combination with SDK > v13
Deprecated
- Python 3.7
v0.29.1 - 02/03/2023
Changed
- Cleaned up sentry error tracking and included curl exit status in sentry error tracking
v0.29.0 - 24/02/2023
Added
- Added support for viktor in requirements.txt without a leading hashtag
- Support Python 3.11 in viktor.config.toml
Changed
- Upgrade to go 1.20
- Added available options for app-type in
create-appcommand help
Deprecated
- Defining viktor in requirements.txt with a leading hashtag
Fixed
- Fix bug that autoreload didn't work if app folder name starts with "test"
- Reverted pip install arguments back to a slice of strings as a single string doesn't work on Windows
v0.28.0 - 08/02/2023
Changed
- Updated install command to be able to insert additional environment variables
- Added "SDK version" to output of
appscommand - Added "App type", "SDK version", and "Python version" to output of
describecommand
v0.27.6 - 03/02/2023
Changed
- Added provided path to error message when python installation is not valid
- Added
--regionflag for multi-region architecture
v0.27.5 - 02/02/2023
Changed
- Added clearer error messages why a Python version is not valid and when the activation code is expired
v0.27.4 - 27/01/2023
Changed
- Track exact error that python path prompt returns, added cli version to sentry message
v0.27.3 - 25/01/2023
Changed
- Add message to get-started command that window shouldn't be closed
v0.27.2 - 23/01/2023
Fixed
- Fixed bug in regex that didn't handle spaces in Python paths correctly
v0.27.1 - 20/01/2023
Added
- Implemented Sentry to track errors in the get-started flow
v0.27.0 - 17/01/2023
Changed
- change configuration name generation to support multiregion
- Place activation code for get-started on newline
- Update warning for python version on how development version can be changed
- Watch entire project folder, instead of just app.py or /app/ folder
Fixed
- Support Python launcher 3.11 regex format when gathering available python installations
