Starter guide
Great to see you are ready to learn how to use VIKTOR! Here you will learn the basics of creating VIKTOR apps!
Before you continue, please make sure you completed the installation / activation instructions which include:
- Installing Python on your computer
- Installing a code editor on your computer (e.g. PyCharm or VS Code)
- Activating your VIKTOR development account
Writing VIKTOR apps requires basic Python knowledge. If you are entirely new to this programming language, we advise to check out "Python for Non-Programmers" which lists learning resources including some nice interactive courses.
Set up the app​
Every new app setup starts by running the quickstart command, which will:
- Download and extract a template app to your machine
- Install the app's Python dependencies
- Prompt to open the app in your code editor of choice
Open Windows PowerShell using Start (or a terminal if you use Linux) and start by running the command below. If you use GitHub Codespaces simply run the command in the terminal of your Codespace.
viktor-cli quickstart hello-viktor
and select your code editor of choice (GitHub Codespaces users don't need to make this choice):
Your app is ready and located at: C:\Users\<USER>\viktor-apps\hello-viktor
? Do you want to open the app code in your code editor? [Use arrows to move, type to filter]
> Open with `VS Code`
Open with `PyCharm Community Edition 20XX.X.X`
Skip
After pressing enter, the code editor will open the folder where the app is extracted to and automatically start the app as shown in the code editor's terminal.
Do not close the terminal as this will break the connection with your app.
Continuing development of an already existing app does not require you to run the quickstart command again. Simply open the
project folder in your code editor and the app will automatically start!
When I try to open the app code I see a warning message regarding trusting the project
You may first see a security warning about trusting projects located in the viktor-apps directory.
- PyCharm
- VS Code
Go ahead and tick the checkbox, followed by clicking the "Trust Project" button:
PyCharm should now open and look similar as shown below:
Go ahead and click the "Trust Folder & Continue"" button:
Subsequently you can click the checkbox to automatically trust all your future apps, and click "Yes, I trust the authors":
VS Code should now open and look similar as shown below:
I get the following error message 'viktor-cli not recognized'
If you activated your account, continued with the starter guide and installed a code editor in the same session you might encounter the following error:
viktor-cli : The term 'viktor-cli' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path
is correct and try again.
At line:1 char:1
+ viktor-cli
+ CategoryInfo : ObjectNotFound: (viktor-cli:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
You can solve this error by closing and restarting your code editor. After doing so you can run the command without any problems. The problem is caused because your code editor inherits the environment variables of the process that launched it and because you installed the VIKTOR CLI in the same session it requires a restart to be recognized properly.
I cannot find my code editor's terminal
You can find the terminal as shown below:
- PyCharm
- VS Code
Where is the app located on my computer?
When you run the quickstart command the app gets downloaded to a folder on your computer.
You can find the app in the following directory: C:\Users\<username>\viktor-apps\hello-viktor.
My app started in Powershell, how can I continue with this starter guide?
If the app starts in Powershell after running the quickstart command this means that you don't have a code editor installed.
Please download a code editor as you will need this to add or modify code of your app. We recommend
using VS Code or PyCharm.
After installation you can open the folder C:\Users\<username>\viktor-apps\hello-viktor in the code editor manually.
Development workspace​
After creating the app and running the quickstart command to download the app code you are ready to start building.
To do so, each app has its own development workspace. This is the place where you can see what your app looks like
and try out the functionalities of the app. You can enter the development workspace in two different ways:
- By clicking the 'Develop' button on the app card. The 3 latest apps you created are shown on the 'Develop' page. Alternatively, you can find all your apps by visiting the App store and selecting 'My apps'.
By following the URL that is shown in the terminal when your app code connects to the VIKTOR platform. This is a direct link to the corresponding development workspace.
INFO :
INFO :
After you have entered the development workspace you should see your app. The app you are creating in this starter guide looks like this:
Create your first input fields​
Open the app.py file in your code editor. This is where you will write the code of your app.
The content should look like this:
welcome = vkt.Text("# 👋 Welcome to your first VIKTOR app! 👋\n## Let's start with the basics")
The app.py file consists of 3 parts:
- (line 1) imports: this is where you import Python modules you use in your app
- (lines 4-5) Parametrization class: this is where you define the inputs of your app
- (lines 8-9) Controller class: this is where you define the outputs (such as visualizations) of your app
A detailed explanation of the folder structure and above concepts can be found here.
- The app will update automatically after adjusting and saving the
app.pyfile (as long as you don't close the terminal!) - Closed your code editor or the terminal inside your editor? Use
viktor-cli startto reconnect the app.
Let's add a NumberField by copying the highlighted line of code. Your app.py file should look like this:
length = vkt.NumberField("Length")
Save the app.py file. This action triggers a reload of your app. This reload is shown in the terminal.
If you made a coding mistake, errors will also be printed in the terminal.
INFO : Reloading app...
Refresh your webpage in the browser to see the "Length" input we just added:
Go ahead and click in the box just beneath "Length" to start typing.
In many cases it is helpful to guide the user by providing a default value for the input fields. You can add a default value of 1 like this:
length = vkt.NumberField("Length", default=1)
Save the app.py file and refresh your webpage in the browser. Any pop-up regarding unsaved changes may be ignored.
After reloading, your app will show the default value:
To conclude the parametrization of our design, we will add 2 more number fields representing the "Width"
and "Height" respectively. Copy the highlighted lines of code below such that your app.py file looks similar:
width = vkt.NumberField("Width", default=1)
height = vkt.NumberField("Height", default=1)
Save the app.py file and refresh your webpage in the browser:
Create your first visualization​
Now let's see how we can use these input fields in a result! In this example we will use the length, width, and height defined in the parametrization as dimensions of a cube. The cube's volume and outer surface area are the results we will show in a table view.
Copy the highlighted lines of code below, such that your app.py file looks like this:
@vkt.TableView("Results")
def results(self, params, **kwargs):
data = [
[1, 2],
[3, 4],
row_headers = ["Row 1", "Row 2"]
column_headers = ["Col 1", "Col 2"]
return vkt.TableResult(data, row_headers=row_headers, column_headers=column_headers)
Great, now let's connect the input values (obtained using the params argument) to the output. We will also rename the row and column headers to be more specific for our app:
volume = params.length * params.width * params.height
surface = 2 * (params.length * params.width + params.length * params.height + params.width * params.height)
data = [
[volume, "m³"],
[surface, "m²"],
row_headers = ["Volume", "Surface"]
column_headers = ["Value", "Unit"]
Well done! You can now adjust the dimensions of the cube and directly see its effect on the volume and outer surface area.
Automate the boring!​
With these basic instructions you now have the skills to build your very own apps!
This is just the tip of the iceberg however. With VIKTOR you can also create 3D models, interactive data visualizations, automated reports, geographic maps and much more... Click the button below to continue your journey!
What's next
Learn more
