Apps: When you release a version to Production or return to an earlier version, the app is ready to use right away. Before, the first run waited for the app to start.
App Builder: When you publish an app, the pre-filled version number follows semantic versioning, for example 1.0.0.
Apps: An app runs again after you return Production to an earlier version. Before, an older version could fail to run if it had not been used for some time.
Admin: On the activity dashboard, the tooltips of the most recent months and weeks show the right date. Before, they showed the same period of the previous year, for example October 2025 instead of October 2026.
SDK: Map views can show your own attribution text, for example a credit for a data source, after the map provider attribution. Available from viktor v14.37.0.
SDK: A LineBreak can be hidden with the visible argument, like other fields. Available from viktor v14.37.0.
Apps: If an entity type name or label is longer than 128 characters, publishing the app now shows a validation error that explains the problem. Before, it failed with a server error.
App Builder: Added functionality to view and delete the files attached to an App Builder conversation as context. The file manager can be opened by clicking the paper clip icon.
Apps: Select several files in a file field or in the file manager of an editor and delete them at once.
Apps: Each app has a Testing and a Production version. Publish a new version to Testing first and release it to your projects when it is ready, or return Production to an earlier version from the versions tab.
Homepage: Describe what you need on the homepage. VIKTOR finds existing apps or projects, or redirects you to the App Builder to build a new app. Building a new app requires developer rights, or an organization that lets users activate developer rights themselves.
App Builder: Switch between Chat and Build in the App Builder chat. In Chat mode, you ask questions about your app without changing it.
MCP: AI assistants that connect to VIKTOR through MCP, such as Claude, can use your apps again. Their requests had been wrongly rejected since v26.10.0.
Admin: Pending access requests of users who already have an account are approved automatically. A pending request no longer stays after the user signs in with SSO using different capitalization in their email address.
Files: Downloaded files keep their original name, including names with spaces, semicolons or special characters. Apps can read uploaded files whose name contains special characters.
