Creating and analyzing a SCIA model
For this tutorial it is assumed that you have already some basic knowledge on how to set up a VIKTOR app. If you are unfamiliar with this process, please do the build your first app tutorial first.
caution
For the section "Performing an analysis" a SCIA worker is required.
This tutorial explains how a SCIA model can be created within VIKTOR, which can be used for analysis using an external coupling. The SCIA model that we will be constructing consists of a foundation slab with piles.
Download the starting app to your hard disk. Run the install
command from within the app folder to install the app
and its dependencies, clear
any previous saved local database, and run start
to start to app:
viktor-cli install
viktor-cli clear
In the browser, click the "Example" entity to open its editor and verify the app is installed and running as expected.
Folder structure
scia-tutorial
├── app.py
├── model.esa
caution
The example template SCIA file (model.esa) in this tutorial has been made in SCIA 19.0. The file cannot be opened nor run with versions < 19.0 (and is not guaranteed to work for > 19.0).
If you are using a version of SCIA other than 19.0, a template file must be created for (and the worker must run) this specific version. This can be done with the following procedure:
- Open a new project in your SCIA version of choice
- Make sure that the material that will be used is present in the materials library
- Setup the XML I/O document to export the desired results (see the SCIA documentation)
- Save the empty file as model.esa
- Replace the existing esa file with the just created one in the foundation folder
Open app.py
and have a look at the code that we have set up for you. Note that the code already creates an empty SCIA
model and some basic class structure. We will extend the code and add specific SCIA objects, step-by-step, throughout
this tutorial.
Creating the corner nodes
If we assume that one of the corner points is located in the origin, the other three corner point locations can easily
be calculated using width_x
and width_y
. Open app.py
and add the following code create_scia_model
def create_scia_model(self, params) -> SciaModel: model = SciaModel() ''' STRUCTURE ''' # create nodes at the slab corners width_x = params.geometry.slab.width_x * 1e-03 width_y = params.geometry.slab.width_y * 1e-03 n1 = model.create_node('n1', 0, 0, 0) # origin n2 = model.create_node('n2', 0, width_y, 0) n3 = model.create_node('n3', width_x, width_y, 0) n4 = model.create_node('n4', width_x, 0, 0) return model
The corner nodes are defined in clockwise direction, since this order will be used later to create a 3D extrusion object.
While setting up a SCIA model in VIKTOR, the 3D visualization is a very helpful feature to verify that the written
logic does indeed create the model as desired. Therefore, we will extend create_visualization_geometries
to get and
show the just created nodes. This can easily be done by calling the nodes
attribute of the SciaModel
...from viktor import Colorfrom viktor.geometry import Point, Sphere, Materialdef create_visualization_geometries(self, params, scia_model): geometries = [] for node in scia_model.nodes: node_obj = Sphere(Point(node.x, node.y, node.z), params.geometry.slab.width_y * 1e-05) node_obj.material = Material('node', color=Color(0, 255, 0)) geometries.append(node_obj) return geometries
Corner nodes
Creating the piles
For the purpose of this tutorial, some parameters like the number of piles and the distance between the piles and the edge are fixed. The locations of these piles however, depend on the dimensions of the slab:
...import numpy as npimport itertoolsdef create_scia_model(self, params) -> SciaModel: ... # create the pile nodes number_of_piles_x = 4 number_of_piles_y = 3 pile_edge_distance = 0.3 pile_length = params.geometry.piles.length start_x = pile_edge_distance end_x = width_x - pile_edge_distance x = np.linspace(start_x, end_x, number_of_piles_x) start_y = pile_edge_distance end_y = width_y - pile_edge_distance y = np.linspace(start_y, end_y, number_of_piles_y) pile_positions = np.array(list(itertools.product(x, y))) pile_top_nodes = [] pile_bottom_nodes = [] for pile_id, (pile_x, pile_y) in enumerate(pile_positions, 1): n_top = model.create_node(f'K:p{pile_id}_t', pile_x, pile_y, 0) n_bottom = model.create_node(f'K:p{pile_id}_b', pile_x, pile_y, -pile_length) pile_top_nodes.append(n_top) pile_bottom_nodes.append(n_bottom) return model
Since we already loop through all the nodes in the create_visualization_geometries
method
(for node in scia_model.nodes:
), the nodes located at the pile ends will automatically be visualized when the app is
(automatically) restarted.
Pile nodes
The top and bottom nodes of the piles can now be used along with the pile diameter defined in the Parametrization
to
create a circular cross-section and beam elements. The cross-section in turn needs a SciaMaterial
as input, which
needs to be defined in the .esa model that is used.
The Material
from the SCIA package is imported with a different name to prevent conflicts with the Material
import
...from viktor.external.scia import Material as SciaMaterialdef create_scia_model(self, params) -> SciaModel: ... # create pile beams pile_diameter = params.geometry.piles.diameter * 1e-03 material = SciaMaterial(0, 'C30/37') cross_section = model.create_circular_cross_section('concrete_pile', material, pile_diameter) pile_beams = [] for pile_id, (n_top, n_bottom) in enumerate(zip(pile_top_nodes, pile_bottom_nodes), 1): pile_beam = model.create_beam(n_top, n_bottom, cross_section) pile_beams.append(pile_beam) return model
For the visualization of the piles, a
CircularExtrusion
is used. This object needs a diameter and
Line
object which specifies the direction of the beam in terms of a start and end
Point
...from viktor.geometry import CircularExtrusion, Linedef create_visualization_geometries(self, params, scia_model): ... # pile beams pile_diameter = params.geometry.piles.diameter * 1e-03 for beam in scia_model.beams: point_top = Point(beam.begin_node.x, beam.begin_node.y, beam.begin_node.z) point_bottom = Point(beam.end_node.x, beam.end_node.y, beam.end_node.z) beam_obj = CircularExtrusion(pile_diameter, Line(point_top, point_bottom)) beam_obj.material = Material('beam', threejs_roughness=1, threejs_opacity=0.3) geometries.append(beam_obj) ...
Pile beams
Creating the slab
The corner nodes that were created earlier can be used to create the concrete slab object. Extend the
create_scia_model
method with the following lines:
...from viktor.external.scia import Planedef create_scia_model(self, params) -> SciaModel: ... # create the concrete slab material = SciaMaterial(0, 'concrete_slab') thickness = params.geometry.slab.thickness * 1e-03 corner_nodes = [n1, n2, n3, n4] slab = model.create_plane(corner_nodes, thickness, name='foundation slab', material=material) return model
Again we can verify the position and dimensions of the created slab by means of visualization:
...from viktor.geometry import Extrusiondef create_visualization_geometries(self, params, scia_model): ... corner_points = [ Point(scia_model.nodes[0].x, scia_model.nodes[0].y, scia_model.nodes[0].z), Point(scia_model.nodes[1].x, scia_model.nodes[1].y, scia_model.nodes[1].z), Point(scia_model.nodes[2].x, scia_model.nodes[2].y, scia_model.nodes[2].z), Point(scia_model.nodes[3].x, scia_model.nodes[3].y, scia_model.nodes[3].z), Point(scia_model.nodes[0].x, scia_model.nodes[0].y, scia_model.nodes[0].z) ] thickness = params.geometry.slab.thickness * 1e-03 slab_obj = Extrusion(corner_points, Line(Point(0, 0, -thickness/2), Point(0, 0, thickness/2))) slab_obj.material = Material('slab', threejs_roughness=1, threejs_opacity=0.3) geometries.append(slab_obj) ...
Slab
Creating the supports
Since the foundation will be completely underground, the following supports have to be attached:
Point supports (
PointSupport
) at the bottom of each pile:...from viktor.external.scia import PointSupportdef create_scia_model(self, params) -> SciaModel: ... ''' SUPPORTS ''' # create pile point supports freedom_v = ( PointSupport.Freedom.FREE, PointSupport.Freedom.FREE, PointSupport.Freedom.FLEXIBLE, PointSupport.Freedom.FREE, PointSupport.Freedom.FREE, PointSupport.Freedom.FREE ) kv = 400 * 1e06 stiffness_v = (0, 0, kv, 0, 0, 0) for pile_id, pile_beam in enumerate(pile_beams, 1): n_bottom = pile_beam.end_node model.create_point_support(f'Sn:p{pile_id}', n_bottom, PointSupport.Type.STANDARD, freedom_v, stiffness_v, PointSupport.CSys.GLOBAL) return model
Line supports (
LineSupport
) on the piles:...from viktor.external.scia import LineSupportdef create_scia_model(self, params) -> SciaModel: ... # create pile line supports kh = 10 * 1e06 for pile_id, pile_beam in enumerate(pile_beams, 1): model.create_line_support_on_beam(pile_beam, x=LineSupport.Freedom.FLEXIBLE, stiffness_x = kh, y=LineSupport.Freedom.FLEXIBLE, stiffness_y = kh, z=LineSupport.Freedom.FREE, rx=LineSupport.Freedom.FREE, ry=LineSupport.Freedom.FREE, rz=LineSupport.Freedom.FREE, c_sys=LineSupport.CSys.GLOBAL) return model
Line supports (
LineSupport
) on the slab edges:...def create_scia_model(self, params) -> SciaModel: ... # create the slab supports stiffness_x = 50 * 1e06 stiffness_y = 50 * 1e06 for edge in (1, 3): model.create_line_support_on_plane((slab, edge), x=LineSupport.Freedom.FLEXIBLE, stiffness_x=stiffness_x, y=LineSupport.Freedom.FREE, z=LineSupport.Freedom.FREE, rx=LineSupport.Freedom.FREE, ry=LineSupport.Freedom.FREE, rz=LineSupport.Freedom.FREE) for edge in (2, 4): model.create_line_support_on_plane((slab, edge), x=LineSupport.Freedom.FREE, y=LineSupport.Freedom.FLEXIBLE, stiffness_y=stiffness_y, z=LineSupport.Freedom.FREE, rx=LineSupport.Freedom.FREE, ry=LineSupport.Freedom.FREE, rz=LineSupport.Freedom.FREE) return model
Creating the load combinations
Adding a load combination to the SCIA model is done in three steps, similarly as in the SCIA interface:
- Create a load group (
LoadGroup
) - Create a load case (
LoadCase
) - Create a load combination (
LoadCombination
...from viktor.external.scia import LoadCase, LoadCombination, LoadGroupdef create_scia_model(self, params) -> SciaModel: ... ''' SETS ''' # create the load group lg = model.create_load_group('LG1', LoadGroup.LoadOption.VARIABLE, LoadGroup.RelationOption.STANDARD, LoadGroup.LoadTypeOption.CAT_G) # create the load case lc = model.create_variable_load_case('LC1', 'first load case', lg, LoadCase.VariableLoadType.STATIC, LoadCase.Specification.STANDARD, LoadCase.Duration.SHORT) # create the load combination load_cases = { lc: 1 } model.create_load_combination('C1', LoadCombination.Type.ENVELOPE_SERVICEABILITY, load_cases) return model
Creating the load(s)
The last component of a complete SCIA model is the actual load that is applied on the structure. In this example, a simple uniform surface load is placed on the slab:
...from viktor.external.scia import SurfaceLoaddef create_scia_model(self, params) -> SciaModel: ... ''' LOADS ''' # create the load force = params.loads.input.uniform_load * 1e03 force *= -1 # in negative Z-direction model.create_surface_load('SF:1', lc, slab, SurfaceLoad.Direction.Z, SurfaceLoad.Type.FORCE, force, SurfaceLoad.CSys.GLOBAL, SurfaceLoad.Location.LENGTH) return model
Downloading the SCIA model
It is always helpful to generate the XML representation of the SCIA model and to manually load this input in the SCIA interface. This will help in verifying that, for example, all the loads are defined correctly in terms of placement and magnitude. In the app we will add a feature to download the necessary files.
In order to be able to view the created model in the SCIA interface, the following three files are needed:
- Empty SCIA model (
*.esa
) - Definition file (
*.def
) - Input file (
*.xml
Now let's fill the download methods that we defined earlier in Foundation
from io import BytesIOfrom pathlib import Path...class Foundation(ViktorController): ... def download_scia_input_esa(self, params, **kwargs): scia_input_esa = self.get_scia_input_esa() filename = "model.esa" return DownloadResult(scia_input_esa, filename) def download_scia_input_xml(self, params, **kwargs): scia_model = self.create_scia_model(params) input_xml, _ = scia_model.generate_xml_input() return DownloadResult(input_xml, 'test.xml') def download_scia_input_def(self, params, **kwargs): m = SciaModel() _, input_def = m.generate_xml_input() return DownloadResult(input_def, 'viktor.xml.def') def get_scia_input_esa(self) -> BytesIO: esa_path = Path(__file__).parent / 'model.esa' scia_input_esa = BytesIO() with open(esa_path, "rb") as esa_file: scia_input_esa.write(esa_file.read()) return scia_input_esa
pathlib's Path
object is VIKTOR's recommended way of defining a path.
You can now download the files from within VIKTOR.
Viewing the model in SCIA
caution
SCIA 19.0 is required if using the example file.
When the files are obtained, the empty .esa model can be opened in SCIA. This model will now be updated with the created input .xml file. In SCIA Engineer:
- Click on
File
->Update
->XML file
- Select the
test.xml
file
It is important that the .xml and the .def files are located in the same directory, and the filename of the .def should not be changed. If this name is changed, make sure to also change the reference to this .def file in the input .xml file.
The updated SCIA model should look like this:
SCIA model generated by VIKTOR
caution
This step requires a SCIA worker.
The three files that are used for the verification above, can now be used as input for the external analysis.
An I/O document has to be defined in the .esa
file, which has to be named "output". If not defined, the worker will
not be able to write this expected document and fails to execute.
In this example, the empty model.esa
has the following structure of the I/O document:
I/O document of the esa model
Let's create a second view, which is a combination of geometry and data (results). Set the duration of this view to 60 seconds, which indicates that it concerns a long-running job with a manual update button. This button will be connected to the SCIA analysis:
...from viktor.external.scia import SciaAnalysisfrom viktor.views import DataGroup, GeometryAndDataView, GeometryAndDataResultclass Foundation(ViktorController): ... @GeometryAndDataView("SCIA result", duration_guess=60) def run_scia(self, params, **kwargs): scia_model = self.create_scia_model(params) # create input files input_xml, input_def = scia_model.generate_xml_input() input_esa = self.get_scia_input_esa() # analyze SCIA model scia_analysis = SciaAnalysis(input_xml, input_def, input_esa) scia_analysis.execute(300) # timeout after 5 minutes data_result = DataGroup() geometries = self.create_visualization_geometries(params, scia_model) return GeometryAndDataResult(geometries, data_result)
After execution, the result can easily be called and parsed as desired.
The "Reactions" results (defined in the I/O document) of the load combination C1 can be parsed from the analysis result using the provided output parser as is shown in the snippet below:
...from viktor.external.scia import OutputFileParserfrom viktor.views import DataItemclass Foundation(ViktorController): ... @GeometryAndDataView(...) def run_scia(self, params, **kwargs): scia_model = self.create_scia_model(params) # create input files input_xml, input_def = scia_model.generate_xml_input() input_esa = self.get_scia_input_esa() # analyze SCIA model scia_analysis = SciaAnalysis(input_xml, input_def, input_esa) scia_analysis.execute(300) # timeout after 5 minutes scia_result = scia_analysis.get_xml_output_file() # parse analysis result result = OutputFileParser.get_result(scia_result, "Reactions", parent='Combinations - C1') reactions = result['Nodal reactions'] max_rz = float(max(reactions['R_z'])) data_result = DataGroup( DataItem('SCIA results', ' ', subgroup=DataGroup( DataItem('Maximum pile reaction', max_rz, suffix='N', number_of_decimals=2) )) ) geometries = self.create_visualization_geometries(params, scia_model) return GeometryAndDataResult(geometries, data_result)
The pile reactions as seen from within the SCIA interface show a maximum of 3.3 kN (depending on your load input):
SCIA analysis result in SCIA
From the result obtained in VIKTOR we can validate that we indeed obtained the maximum reaction force of this load combination:
SCIA analysis result obtained in VIKTOR
