Workspaces and apps
This page explains the concepts of workspaces and apps, shows their location in the interface and explains what can be configured.
Workspaces
A VIKTOR environment may consist of multiple workspaces which are shown on the landing page when logging in. Each card represents a workspace and consists of a brief description of the functionalities together with an image. Users enter a workspace to perform calculations, export reports and do other work.
Workspace visibility
The visibility of a workspace defines who can see the workspace and can be changed by a workspace admin or environment admin.
  • Internal: All users of the environment can see and access the workspace, except users flagged as "external".
  • Private: Only invited users can see and access the workspace.
Workspace vs. app
A normal user mainly interacts with workspaces: this is where calculations can be made. Developers and administrators however also interact with apps. This section explains the difference between them.
What makes this a bit difficult is that the term "app" is also used for fully functional applications on your phone. Within VIKTOR an app itself is not yet usable for an end-user as will be explained below (this is a workspace).
App
An app contains your logic and all the code that the programmer wrote: how the app is structured, how the input is organized, what the output looks like and what calculations should be performed (the entity types and their structure).
As an example, you could have an app for calculating the volume of a beam. The app defines:
  • input: length, width, height
  • output: 3d model of beam, calculated volume
  • calculation: vol = length * width * height
This app cannot yet be used by users. It misses the data: which users have access and the actual values that they inserted and stored.
Workspace
A workspace is the actual place where a user can perform calculations. In short, it's an app + data: both user and calculation data. If the app is a .exe, the workspace corresponds to the fully installed version of the simulation software on a particular computer.
You can have multiple workspaces of the same app with different data. For instance, you can create workspaces for different projects or split users between two different workspaces to separate the data and make sure that they cannot see each other's work:
Apps in the interface
Normal users will not be aware of apps and will only see workspaces. Developers and administrators however have an extra menu item called "Apps" in which they can manage apps (create, read, update):
overview of apps
Opening an app shows a details page where you find the description of the app, maintainers and latest version.
app details page
The second tab shows all the versions of this app, accompanied by the publication date and developer that published this version:
app versions page
Creating an app
Apps can be created by administrators and developers. Developers are automatically assigned as the first maintainer on the app.
Creating a workspace
Workspaces always have an app assigned to it. You can either select an existing app or be directed to the page i which you can create a new app.
Updating an existing workspace
An administrator can edit a workspace by clicking on the three dots on the corresponding card in the workspaces panel. A modal opens in which you will be guided through the same steps as during the creation process.
