Using a calculation spreadsheet
In this tutorial we will create an application to analyze a simply supported beam under load. A spreadsheet will be used for the calculations.
  • The starting app for this tutorial can be downloaded here.
  • The end result can be downloaded here.
Download the starting app to your hard disk. Run the install command from within the app folder to install the app and its dependencies, clear any previous saved local database, and run start to start to app:
viktor-cli install
viktor-cli clear
In the browser, click the "Example" entity to open its editor and verify the app is installed and running as expected.
Folder structure
spreadsheet-tutorial
├── app.py
├── beam_calculation.xls [1]
├── beam_schematic.svg
[1] source: https://stuff.mit.edu (04-05-2020)
Open app.py and have a look at the code that we have set up for you. Note that the code already has some basic class structure. We will extend the code, step-by-step, throughout this tutorial.
Preparing the spreadsheet
To be able to use a spreadsheet as a calculation tool within a VIKTOR app, a few modifications must be performed to the spreadsheet file. Open beam_calculation.xls and add two sheets: viktor-input-sheet and viktor-output-sheet. These sheets contain the input and output values respectively. In the viktor-input-sheet, add the following data:
The values from viktor-input-sheet should now be used in the Analysis sheet. For example, cell C22 below refers to the "L" parameter defined in the viktor-input-sheet sheet:
In the viktor-output-sheet the desired output parameters are defined, with their values taken from the Analysis sheet:
You should now be able to change the values on the viktor-input-sheet, resulting in changed values in the viktor-output-sheet.
Coupling the spreadsheet
The spreadsheet is now ready for use within the app. VIKTOR provides a helper class specifically for this task: SpreadsheetCalculation. Open app.py and replace the method get_data_view with the following code (mind the extra imports):
from viktor.external.spreadsheet import SpreadsheetCalculationInput, SpreadsheetCalculationclass Calculation(ViktorController):    ...    @DataView('Results', duration_guess=1)    def get_data_view(self, params, **kwargs):        inputs = [            SpreadsheetCalculationInput('L', params.beam.length),            SpreadsheetCalculationInput('W', params.beam.width),            SpreadsheetCalculationInput('H', params.beam.height),            SpreadsheetCalculationInput('E', params.beam.E),            SpreadsheetCalculationInput('aw', params.loads.aw),            SpreadsheetCalculationInput('wa', params.loads.wa),            SpreadsheetCalculationInput('wL', params.loads.wL),        ]        sheet_path = Path(__file__).parent / 'beam_calculation.xls'        sheet = SpreadsheetCalculation.from_path(sheet_path, inputs=inputs)        result = sheet.evaluate(include_filled_file=True)        print(result.values)        data = DataGroup(            maximum_deflection=DataItem('Maximum deflection', -10, suffix='microns', number_of_decimals=2),            maximum_bending_stress=DataItem('Maximum bending stress', -13, suffix='N/mm2', number_of_decimals=2),        )        return DataResult(data)
The input parameters are accessed from the params dictionary and follow the same structure as defined in the parametrization class.
In your browser change the value of Length from 100 to 120 and notice that the updated values are now printed to the command-line.
Showing the output
To display the output in the app's interface, the parameters from the result dictionary must be linked to the DataItems, as shown below. Modify the method get_data_view as follows:
data = DataGroup(
maximum_deflection=DataItem('Maximum deflection', result.values['maximum_deflection'], suffix='microns', number_of_decimals=2),
maximum_bending_stress=DataItem('Maximum bending stress', result.values['maximum_bending_stress'], suffix='N/mm2', number_of_decimals=2),
Confirm that changing the value in your browser gives you different outputs in the DataView.
Downloading the spreadsheet
A nice addition to the app would be that the sheet, used for the calculation, can be downloaded. Add a DownloadButton to the parametrization (mind the extra import):
from viktor.parametrization import ..., DownloadButton
downloads = Section('Downloads')
downloads.spreadsheet = DownloadButton('Download', 'download_spreadsheet')
The download_spreadsheet method should contain the downloading logic and must be added in the Calculation class. To prevent writing duplicate code, however, we will first restructure this code a bit. Let's create a new method called get_evaluated_spreadsheet, which will be called by both get_data_view and download_spreadsheet:
class Calculation(ViktorController):    ...    def get_evaluated_spreadsheet(self, params):        inputs = [            SpreadsheetCalculationInput('L', params.beam.length),            SpreadsheetCalculationInput('W', params.beam.width),            SpreadsheetCalculationInput('H', params.beam.height),            SpreadsheetCalculationInput('E', params.beam.E),            SpreadsheetCalculationInput('aw', params.loads.aw),            SpreadsheetCalculationInput('wa', params.loads.wa),            SpreadsheetCalculationInput('wL', params.loads.wL),        ]        sheet_path = Path(__file__).parent / 'beam_calculation.xls'        sheet = SpreadsheetCalculation.from_path(sheet_path, inputs=inputs)        result = sheet.evaluate(include_filled_file=True)        return result    @DataView('Results', duration_guess=1)    def get_data_view(self, params, **kwargs):        result = self.get_evaluated_spreadsheet(params)        max_deflection = result.values['maximum_deflection']        max_bending_stress = result.values['maximum_bending_stress']        data = DataGroup(            maximum_deflection=DataItem('Maximum deflection', max_deflection, suffix='microns', number_of_decimals=2),            maximum_bending_stress=DataItem('Maximum bending stress', max_bending_stress, suffix='N/mm2', number_of_decimals=2),        )        return DataResult(data)
Now we add the method download_spreadsheet, which uses this newly created method (mind the extra import):
from viktor.result import DownloadResult
def download_spreadsheet(self, params, **kwargs):
return DownloadResult(result.file_content, 'evaluated_beam.xlsx')
Confirm that the download button functions as expected.
